Coolant hoses
Old Dec 31, 2010 | 02:30 AM
zeeshan's Avatar
Coolant hoses
Tried to search. Is the barb on the rear rotor housing near the intake manifold a feed or return and what does it plumb to in its factory state? Also does anyone have a pic of where they feed coolant and return their coolant from for their single turbo setup? Thank you
Old Dec 31, 2010 | 08:31 AM
dgeesaman's Avatar
It is a coolant line that runs to the backside of the throttle body on stock cars.
I believe it's necessary to keep this plumbed in some manner.
I recommend looking in the cooling system threads. You'll find these in the FAQ sticky.
David
Old Dec 31, 2010 | 12:01 PM
zeeshan's Avatar
thank you, found the thread
Old Dec 31, 2010 | 01:59 PM
Sgtblue's Avatar
Urban Combat Vet
Coolant at that fitting/point is just leaving the combustion side of both housings and irons. Good place for an aftermarket temp sender, but probably not going to a good source for your single turbo coolant line.
Old Dec 31, 2010 | 04:24 PM
Mitchocalypse's Avatar
Brap..
that's probably my favorite picture of all time. When I get my own place, I will have it blown up and framed.
Old Jan 1, 2011 | 02:08 AM
zeeshan's Avatar
from the looks of this diagram, i can simply bypass the tb coolant lines by running a coolant hose from the rear rotor housing to the thermostat housing. awesome!
Old Jan 1, 2011 | 06:15 AM
Sgtblue's Avatar
Urban Combat Vet
Yes, you can.
Old Jan 2, 2011 | 12:06 PM
zeeshan's Avatar
done!
7upra
Mar 25, 2018 11:32 AM
LongDuck
Oct 7, 2015 08:12 PM
localized
Sep 16, 2015 12:18 AM
