Door Switches --How they Hook up??
Old Dec 21, 2010 | 03:56 PM
ppritchard's Avatar
93 Touring
FL Door Switches --How they Hook up??
Just received new door switches (lights on etc) and it looks like the old wiring prong was different on our car than the new switches have?
The wire/prong on the right is what has been in the car and the new switch on the left is the plunger.
I may be missing a piece or perhaps the switch was changed over time, anyone know/remember?
Thanks for any help,
Old Dec 21, 2010 | 04:38 PM
rxtasy3's Avatar
looks like that plug has a release on it that will allow that brass piece to come out.
Old Dec 21, 2010 | 05:01 PM
RX-7 Chris's Avatar
that doesn't look at all like a first gen switch. Is this in the right section?
Old Dec 21, 2010 | 10:42 PM
DivinDriver's Avatar
1st-Class Engine Janitor
First-gen switches mount with two philips screws, and the wire terminal screws onto the end.
Old Dec 21, 2010 | 10:56 PM
1badFB's Avatar
GSSL-SE
Looks like an FD switch to me.
And as said above it looks like someone pulled the contact out of the original switch.
Button gets pushed on the black connector, copper contact piece slides out, after that it should just plug right in.
Old Dec 22, 2010 | 01:02 AM
Prôdigy2nd's Avatar
I
This, you have the old wire blade stuck in the connector pull it out, and it will all make sense..
as stated above, push the center "button" down to pull blade out...
J.
Old Dec 22, 2010 | 07:45 AM
JdmRX's Avatar
1262@54psi
these are the new switches that mazda sells now with the boot
Old Jan 2, 2011 | 06:28 PM
ppritchard's Avatar
93 Touring
Used the pliers and pulled out old pieces, plugged in the new switches and all is good.
Thanks for the help.
