Power FC using PFC from another car
Old Dec 21, 2010 | 01:25 PM
BlueTuner's Avatar
Unconfirmed
will it be safe to use a pfc from one fd in another fd.
The only difference between both fd's, is the fd the pfc was tuned in is auto, and has a bigger intercooler,
the new fd the pfc is going in has a stock intercooler, and a manual, everything else is the same.
Old Dec 21, 2010 | 04:44 PM
tom94RX-7's Avatar
It may work ok for you, stock boost levels? you should get a wideband if you don't have one to monitor the afr's and tune the afrs if needed
Old Dec 21, 2010 | 04:58 PM
arghx's Avatar
rotorhead
rather risky, don't you think?
Old Dec 21, 2010 | 05:40 PM
BlueTuner's Avatar
Unconfirmed
yes stock boost levels, both cars have the same modifications, only difference is transmission and intercooler.
Old Dec 21, 2010 | 08:30 PM
cewrx7r1's Avatar
Eye In The Sky
If that is true, and the auto ran correctly and safe on boost; then the only difference should be the idle setup rpms.
Old Dec 21, 2010 | 08:48 PM
BlueTuner's Avatar
Unconfirmed
very cool, what do you mean by a different idle setup
Old Dec 21, 2010 | 11:30 PM
tom94RX-7's Avatar
The tuner may have tuned the idle cells in the fuel and timing maps p4-6 and n2-3, you may want to or need to adjust these for a smoother idle, and the idle air adjustment screw. and some of the ign settings may have been changed using the commander or datalogit.
Old Dec 22, 2010 | 11:10 AM
cewrx7r1's Avatar
Eye In The Sky
Auto trans engine have different idle adjustment due to idleing in gear while a standard idles in neutral. Got it.
cristoDathird
28
May 30, 2019 08:47 PM
torky007
Aug 17, 2015 05:14 PM
Snook
Aug 15, 2015 08:18 AM
blkops
Aug 12, 2015 01:30 PM
