No lights NEED HELP
Old Dec 18, 2010 | 04:48 PM
BlueTuner's Avatar
Unconfirmed
No lights NEED HELP
Ok, so i have no dash lights, no climate control lights, but i do have a odometer light.
I dont have any parking lights, but if i use my brakes my brake lights go on.
I checked my fuses, all are good, i swaped the relay and tps relays, the blue ones, with another rx7 that was working.
Still nothing, any idea's.
really need the help right now.
Old Dec 18, 2010 | 05:32 PM
fendamonky's Avatar
F'n Newbie...
I had a similar issue several years ago, except I was blowing a fuse.
Mine ended up having a short in the wiring behind the radio in the dash.
Old Dec 18, 2010 | 06:20 PM
hades's Avatar
i blew the BTN fuse under the hood. took out all sorts of stuff--lights, radio, locks, etc. I would check that.
Old Dec 18, 2010 | 09:08 PM
BlueTuner's Avatar
Unconfirmed
I've check all the fuses, so im gonna look at the radio, what should I look for?
Thanks
Old Dec 19, 2010 | 10:41 PM
turboIIrotary's Avatar
Jump the white/green wire to the red/black wire where the TNS relay goes and see if the lights turn on. If not check if there is 12v at the white/green wire if there isn't check in this order.
15amp tail
60amp btn
120 amp main
Old Dec 20, 2010 | 03:37 PM
BlueTuner's Avatar
Unconfirmed
15amp tail
60amp btn
120 amp main
I dont know what that means, but i checked the wires behind the radio and everything looks good. But still dont have parking lights or dash lights.
Old Dec 20, 2010 | 03:46 PM
MR_Rick's Avatar
Planning my come back
Have you done any work in the shifter area? I had this issue a while back after I changed my clutch. There is a wire that runs on top of the tunnel and it got pinched under the screw on the rubber boot for the shifter and it cause me to loose all the lights but parking lights and brake lights.
Old Dec 20, 2010 | 03:52 PM
moconnor's Avatar
The Body Electric Troubleshooting manual (in the stickies) has diagnostic procedures for pretty much all electrical circuits in the car.
Old Dec 20, 2010 | 05:59 PM
BlueTuner's Avatar
Unconfirmed
I just got the car so i really dont have much info about it, but when i pulled the center console off, there was a blue plug that i couldnt find what it went to, also for some reason, my radio ground was grounded to the plastic piece that covers the transmission, so was my hks turbo timer.
also my window switches dont work at all, the window swtich and mirrior adjusters dont work.
when i took out the radio, there was a set of wires cut, like 5 of them, what do those go to.
Old Dec 20, 2010 | 06:05 PM
moconnor's Avatar
Did you look in the electrical wiring manuals in the stickies?
Old Dec 20, 2010 | 06:28 PM
BlueTuner's Avatar
Unconfirmed
couldnt find the sticky (really didnt look to hard for it)
BUT good new i got everything working,
i just swaped a couple fuses that where the same around, and while i was doing that with the small fuse box that is connects the batteries positive, i heard a click when i grabbed the hole fuse box, so in my understanding it was ether,
a lose connection to the fuse box from the connector underneath the fuse box,
or
i had a blown fuse that didn't look blown.
but for now i do have all my lights back, hopefully i still have everything else because i haven't started the car yet.
But, im just gonna go to the store and buy new fuses for every fuse and replace them, just in case.
I appreciate all the help guys
Old Dec 20, 2010 | 06:31 PM
moosejaw's Avatar
Check your relays at the front of the car
Old Dec 20, 2010 | 07:04 PM
camajo's Avatar
Screw some wire caps onto the lose wires and see if that keeps the fuse from blowing. The blue wire in a car stereo set is typically a remote turn on lead for an amp or a power antenna. I had the exact same problem recently after a car stereo installation where the blue wire was blowing the fuse for the dash lights. In my case the blue wire was insulated to the tip but the small bit of copper on the very tip of the wire made contact with some metal behind the head unit which kept blowing that fuse.
Good luck.
JoesFC
Oct 5, 2015 08:10 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
