white smoke like a burnout on 6500
Old Jul 3, 2002 | 04:01 AM
ryandogg's Avatar
Unhappy white smoke like a burnout on 6500
hello every one ... once again a complication on a series 4 88 fc turbo 2.. well heres the deal. and yes ive searched..
- it seems as i boost thru the rpms until i get to 6500 and then poof. like 3-5 sec burn out would look like. the amount of smoke is unbelieved. it spooked the **** out of me when this happened. i noticed it a couple of days after i gutted my cat.. can i get some opinions, and facts on this guys..
my mods are tid mod, gutted motor. no ac/ps/airpump. and some other msc parts, gutted cat(main), and some weigh reduction. . please help im worried that my motor is toast.. thankx https://www.rx7club.com/forum/attach...&postid=691203
Old Jul 3, 2002 | 04:11 AM
Juan's Avatar
Im a tall midget.
does the smoke come out of the engine bay or the exhaust??
what color is the smoke? white or blue?
does it smoke all the time after 6500? or once in a while?
Old Jul 3, 2002 | 04:33 AM
ryandogg's Avatar
well its exhaust. but theres so much and when i rev sittin still it comes from everywhere.. its really that bad. and the color of the smoke is white.. which im GUESSIN' a coolant leak in the motor, maybe. im not sure..
it smoke when the oil and the engines cold. but not as bad as when its warm. but @ 6500 white smoke everywhere... heeeeeeeeeeeeeeeeeelp....
Old Jul 3, 2002 | 04:39 AM
The Ace's Avatar
Greek Power
Well the obvious things to check are the 5-6 hoses that run coolant around the engine (to-from BAC, to-from TB, to-from Heater). Does your coolant level drop at all ? Do you get the buzzer ?
And more importantly: does the engine struggle to start after sitting for a while ? (i.e does coolant drop into the housings ?). A little white smoke when engine is cold (at startup) is almost normal, but not the quantities that you are mentioning....
check the hoses first....
Old Jul 3, 2002 | 05:34 AM
ryandogg's Avatar
the car is hard to start sometimes when its been sitting. but i think that was causes by the most infanous floodin on the fc's.. ived checked all of the hoses, and the connecting clamps and there are no leaks.. but i did have a coolant leak at the bottom hose of the lower radiator hose, but id now fixed .
and as for the coolant level it seems to be normal.
and there is no buzzer. the car did run hotter than b4. but it was because i took off the radiator shround and the cont intake thing on the top of the shround. as of installation. car temp seem to have lowered dramaticly.. i hope this helps...so please heeeeeeelp..
Old Jul 3, 2002 | 06:00 AM
Roy James's Avatar
My cars louder than yours
Oil O rings?
Old Jul 3, 2002 | 06:54 AM
2887s's Avatar
Do you go through alot of oil? My NA convertible does the same thing, I don't know if it is the OMP, or what.
Old Jul 3, 2002 | 04:29 PM
ryandogg's Avatar
hmm... ill let you know if its the omp im gonna check it.
Old Jul 3, 2002 | 04:45 PM
HN's Avatar
HN
check compression. i had that happen to me and it was a broken sside seal. everything was fine but at high rpms it would look like i was working for the city.
Old Jul 3, 2002 | 09:46 PM
ryandogg's Avatar
nope. i checked the compression and i got 90 psi on all of em.. so this is a good sign..what is the compression with a bad seal. im guessin anything lower than 90, right.
anyone else got any other ideas.
Old Sep 13, 2002 | 12:27 PM
BKC TURBO's Avatar
I get to 6500 and once in a while i get the exhaust backfire igniting causing some smoke behind me. Don't know if that is what is happening.
antman0408
Oct 5, 2015 04:33 PM
SpaceCadet_Alt3
Oct 1, 2015 11:35 PM
frosty1993
Sep 30, 2015 01:27 PM
dexter snoek
Sep 29, 2015 09:18 AM
