Megasquirt Where is my bad ground
Old Dec 11, 2010 | 10:08 PM
gfd263's Avatar
Mega squirt came up fine with stim after completion. All LEDs were lit on pcb and 3 on stim, but apparently the battery was weak. It died in just a few minutes. Put plug in adapter on stim, and now nothing. Polarity is correct. I have power all over the board, but there is a bad ground that is not showing itelf. LEDs have power, but not grounding. Transistors q6, q7, and q8 are grounded at terminal 1. Jumped the LED negative to power supply and it lit.
Old Dec 13, 2010 | 03:57 PM
gfd263's Avatar
Update!!! While checking voltages, I bumped D7to the near leg of D15. I2 on the stim lit. So for kicks, I jumped D5 to the near leg of D15 lighting I1. Now to look at schematics to see if they have a common ground.
rgordon1979
40
Mar 15, 2022 12:04 PM
ricardo.benin
Sep 22, 2015 12:06 PM
Donald Hampton
Sep 20, 2015 09:09 PM
rotor_veux
Sep 19, 2015 07:13 PM
