Sanity Check - Tranmission Wiring
Old Nov 26, 2010 | 07:06 PM
wrankin's Avatar
Old Rotary Dog
Hey Gang,
I'm in the process of trying to trace a wiring short in my FC (blowing meter fuses after several minutes on track) and I wanted to verify that I can disconnect the "Over Top" and "Backup Light" switches on the transmission w/o affecting the ECU operation. It's a track-only non-road car, so I do not need backup lights.
Car is an S5 with no emissions and a stock ECU. I am under the impression that I do have to have the "Neutral Switch" connected.[*]
Anybody see a problem?
Thanks,
-bill
[*] hmm, I wonder if the neutral switch affects the ecu and could make it go lean....
Old Nov 27, 2010 | 03:51 PM
SCCAITS's Avatar
SCCAEP
Never had any wires from the tranny hooked up and worked fine with a stock ECU for me before.
Old Nov 29, 2010 | 08:15 PM
wrankin's Avatar
Old Rotary Dog
Well I ran the car for the past two days at the track with the Over Top and Reverse switches disconnected. No problems seen and in addition the meter fuse never blew. I may play some next time out disconnecting the neutral switch and seeing the results.
Boriquaguerrero
20
Apr 22, 2019 01:15 PM
The Shaolin
Sep 14, 2015 07:50 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
PhillyFC
Aug 21, 2015 06:36 PM
fastsaab
Aug 19, 2015 11:42 AM
