Fabrication Post your questions and projects on Fabrication of Interior or Exterior or custom audio and electronics here.
Holset velocity stack
Old Nov 19, 2010 | 11:28 AM
2a+RoN's Avatar
It seemed like the inlet to my turbo wasn't really optimized for flow, so I decided to whip up a quick velocity stack ring for the anti-surge housing.. Not sure how much it helped but it's removable so I can do back to back testing at some point.
Drilling holes.
Ready to part.
Rough inlet angles cut.
After finishing inlet stack.
Backside machine work.
Ready to drop into housing.
Old Nov 20, 2010 | 08:15 AM
Carlos Iglesias's Avatar
Corn-to-Noise Converter
Veteran: Navy
Top Answer: 1
Nobody like a show-off Aaron, especially with your fancy machining tool!! ;-)
All kiddin aside, it looks very well-thoughout and just plain cool, so I'll await your furthering success stories.
Old Nov 20, 2010 | 12:42 PM
blue87's Avatar
Very nice work, looks pretty, quality craftsmanship.
I am not sure if it will actually do anything as the opening on the Holset is pretty wide and short... FWIW though It looks like something I would obsess over and do if I had the time/tools .
You don't think the ring will be forced out when you let off the throttle from air coming back through the anti surge shroud do you? or is it pressed in there pretty tight?
+1 on wanting to see success stories!
Old Nov 20, 2010 | 04:06 PM
staticguitar313's Avatar
R.I.P. Icemark
damn Aaron thats pretty win!
Old Nov 20, 2010 | 10:06 PM
2a+RoN's Avatar
Thanks guys! Yeah, I'm not too sure it'll do anything either, but I had an itch to make it, so I did..
It's basically pressed in so will require some major effort for when/if I decide to remove it.
I want to start taking more pictures of the little things I've been working on, so should hopefully have some more good stuff to post soon.
Old Nov 21, 2010 | 12:08 AM
Jaiyurai's Avatar
Endure Persevere Succeed
wow. Definitely a thumbs up Aaron.
I'll be visiting you when I come back to Arizona next month.
Old Nov 21, 2010 | 06:08 AM
Veteran: Navy
Top Answer: 1
You should do like all of us rotary-narcissist, and start you own <forgive the military term> "I Love Me" thread. I'll even throw out a title for your consideration: Aaron Innnovation Funhouse!
Old Nov 22, 2010 | 12:10 PM
2a+RoN's Avatar
Hahaha, I might just have to do that!
Old Nov 22, 2010 | 01:47 PM
gawdodirt's Avatar
Been here since dirt...
AZ
Looks good! What are the radii of the diameter and the opening?
I'm in Gilbert. Where is your shop?
GD
Old Nov 24, 2010 | 01:30 PM
2a+RoN's Avatar
I'm not sure I know exactly what you mean...? The velocity stack radius I finished by hand, but I'm guessing somewhere around .75 to 1" radius. The inlet opening diameter is ~2.4", and the outer diameter of the ring is ~3.6". Hope that answers your question.
I work at YawPower/Injector Dynamics in Phoenix.
Old Nov 24, 2010 | 08:06 PM
dj55b's Avatar
what's the purpose of the drilled holes on the outside ?
Old Nov 24, 2010 | 10:12 PM
sen2two's Avatar
Rx2 > FD
Anti-surge...
Holsett turbos are built for diesel trucks, which do not use BOV's. So instead of air surging through the compressor putting unwanted force on the compressor possibly causing it to rotate the opposite way, it sneaks out through that area.
Old Nov 24, 2010 | 10:16 PM
sen2two's Avatar
Rx2 > FD
Your idea is way better than mine. But here's what I did to my Holsett (not trying to thread jack, just bored)
Beveled and radius the inlet and removed as much material as possible. The intake attaches to just the main inlet with a velocity stack on the end of that.
Stock:
Modded:
Did this to a friends GT28, he noticed a faster spool up. Have not tested this one yet.
Old Nov 25, 2010 | 09:33 AM
2a+RoN's Avatar
Looks good! Unfortunately my lathe isn't large enough to get the entire housing chucked up.. I would've liked to taper further down on the inlet like you did, but I drove the car to the shop that day and was running out of time.
Old Nov 25, 2010 | 01:15 PM
gawdodirt's Avatar
I have done alot fo flow work where I used to work and we used exclusively "3-D " orifice nozzles. The length of the straight section is the diameter, and the radii is also the radius of the opening opening dimension.
That anti surge opening looks like it could kill a ton of velocity. Can you plug it off since you have the ability to install a BOV?
GD
Old Nov 28, 2010 | 12:37 AM
levelzero's Avatar
On the trucks some of the turbos cams with a plate over the antisurge ports. Removing the plate made the turbos much louder but also spooled up a bit faster.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
NotMrButts
Feb 10, 2018 06:36 PM
Wicked93gs
Aug 23, 2015 10:14 AM
