Gainesville Florida Wing Run to Ocala
Old Nov 16, 2010 | 12:17 AM
Gringo Grande's Avatar
1.5 Goodfella's Tall
Choose a Day this coming weekend: Saturday or Sunday?
1) GG
Old Nov 16, 2010 | 10:06 AM
Ruler_Mark's Avatar
I can't see my car **(
1) GG
2) RM - both are good
Old Nov 16, 2010 | 06:02 PM
evot23's Avatar
Classy
I will most likely not be going with father in law at hospital. Will be on the home front...probably looking to fix electrical issues.
Old Nov 16, 2010 | 06:05 PM
MastrChase's Avatar
OasisAvatar
What time? I work till 6 both days
Old Nov 16, 2010 | 07:20 PM
evot23's Avatar
Classy
Be sure to hit Tom up
Old Nov 16, 2010 | 08:05 PM
Change the Wing Run to work on cars at Eddie's House?
Old Nov 16, 2010 | 08:35 PM
Ruler_Mark's Avatar
my project is immobile
Old Nov 16, 2010 | 11:08 PM
MastrChase's Avatar
OasisAvatar
No, wing run on Sunday at 7pm. My vote.
Old Nov 17, 2010 | 05:36 AM
evot23's Avatar
Classy
Possible, unless father in law discharges from the hospital, in which case I will be busy.
TROUBLESHOOT this:
Driving to Markham Park on I95 South, come to dead stop traffic (semi burning down). So we decide to shut the car off to "save gas".
Go to start it and NOTHING. No click, don't hear my fuel pump, acts like a dead battery but I was reading 14.2 volts up til now. Kept trying to start it about 5 times then all of a sudden it hiccups a little so I give it some gas to get it started.
Runs like a champ all the way down to Miami but my scangauge OBDII reader is going haywire..on/off/on/wrong data/etc. Other than that I have good power, no other apparent issues.
Park it at the meet, shut it off, try to start it again and NOTHING.&^&^%(^_^_*(&&$&^%$^%$
So I start looking for issues. Battery connected, good grounds, fuel pump wires all intact, OBDII connected properly (checked it for the scangauge, not essential to start the car). I can't find ****.
So I try to start the car again and the monster is ALIVE!! So I jiggled something and have it running again albeit now I'm a little gun shy. Voltmeter out last night and it seems I'm getting power to PCM, good connectivity to fuel pump relay, good grounds (checked again), good everything as far as I can tell. NO codes pulled up.
I'm clueless as to what happened....thoughts???
Old Nov 17, 2010 | 08:58 AM
Ruler_Mark's Avatar
any security systems?
Old Nov 17, 2010 | 10:03 AM
Go back to rotary? =)
Is this the same issue you had during the last Hooter's run? Check your fender linings just to make sure nothing has been eaten through? Any rain/moisture on the trip?
Electrical is the worst I swear.
Old Nov 17, 2010 | 01:03 PM
evot23's Avatar
Classy
Just the stock system.
No, that issue I resolved. I'll have to check to make sure everything is good underneath, no rain or moisture on the trip.
Old Nov 17, 2010 | 01:05 PM
Stock System is notorious for going bad and causing issues. Check with Mark as I know you can jumper it easily to disable the system.
Old Nov 17, 2010 | 01:23 PM
evot23's Avatar
Classy
Yes, yes, yes...I'd like to simplify!
Old Nov 17, 2010 | 01:28 PM
evot23's Avatar
Classy
I wonder if I jarred something by that relay...I was down there the night before hooking up the fans to the 12V switched source...hmmm...will still have to trouble shoot the scangauge...prob a bad ground somewhere or shotty B+ running around. Have the V8 guys offerring up help too.
I'll jump the relay tonight for good measure. good call on that one fellas.
Old Nov 17, 2010 | 01:49 PM
Ruler_Mark's Avatar
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/one-possible-fix-click-click-start-problem-remove-oem-security-relay-872841/
Old Nov 18, 2010 | 05:31 PM
MastrChase's Avatar
OasisAvatar
So.. about the topic at hand.... lol.
Old Nov 18, 2010 | 06:43 PM
At the moment it is not taking place.
Old Nov 19, 2010 | 07:28 AM
evot23's Avatar
Classy
If my father in law wasn't in hospital, I'd be all over my car right now. Decided I need to redo some wires, rewire my battery relocation and move some fuse boxes.
Gringo, if you are going to do battery relocation, now is the time to get ready. I feel like tackling electrical garbage!
Old Nov 19, 2010 | 09:12 AM
Ruler_Mark's Avatar
its very easy todo, installing 2 gauges is harder imo
Old Nov 19, 2010 | 02:48 PM
evot23's Avatar
Classy
I have battery relocated already...just have to make it CLEAN. also want to move long relay box up front to another location along with my fuses on driver side.
Old Nov 19, 2010 | 02:49 PM
evot23's Avatar
Classy
Need good crimper and good soldering iron.
Old Nov 19, 2010 | 02:51 PM
evot23's Avatar
Classy
Anyone know a good place to buy automotive wire on the cheap?
Old Nov 19, 2010 | 04:50 PM
I believe I have a soldering iron...thought you had a crimper? I've got one now also. Can't you get auto wire from Lowe's or HD? Call Audio Outlet and tell Jonny the owner that Kevin sent you and see what he offers.
Old Nov 19, 2010 | 06:38 PM
evot23's Avatar
Classy
looking for a better crimper to use on open barrel terminal ends..I may be doing a lot of them so figured I'd maybe invest in some quality ones. I'll keep the reference in mind if I don't find what I need at Autozone or PepBoys for gauge wire I need.
fastrx7man
33
Sep 2, 2015 09:42 PM
MILOS7
Aug 19, 2015 07:25 AM
