Msd Ignition Help Please!!!
Old Jul 1, 2002 | 10:50 PM
Dustin Setayesh's Avatar
I have a MSD 6BTM and I hooked up the leading and trailing coils like the MSD manual says but have no tachometer . Any help would be appreciated. Also should I have hooked up the leading and trailings to the same unit? I know the leading and trailing are at 5 and 20 degrees respectively. All I hooked up was th hot and ground to the coils.
Dustin
No tach turbo II
Old Jul 1, 2002 | 11:16 PM
Scott 89t2's Avatar
SOLD THE RX-7!
umm... you can only hook it up to the leading coil. put your trailing back to stock. it's probably not even firing right now since that's where the tach signal comes from.
Old Jul 2, 2002 | 01:33 AM
Racer 13B's Avatar
Yeah hook it up to the leading coil pack only. You will need two additional msd boxes if you want to do the trailing coil packs.
Scott C.
Old Jul 2, 2002 | 09:34 AM
Thanks for the advice I figured as much.
dona1326cosprings7
Oct 29, 2015 06:47 AM
eplusz
15
Oct 7, 2015 04:04 PM
GKW
Sep 28, 2015 04:34 PM
subeone
Sep 24, 2015 09:58 PM
