2nd Gen ITS exhaust
Old Nov 11, 2010 | 09:56 AM
wlfpkrcn's Avatar
2nd Gen ITS exhaust
Long or short primary pipes? Currently we have long primary pipes and it completely gutless. I'm thinking of shortening them to try to bump up the torque
Old Nov 11, 2010 | 04:13 PM
jgrewe's Avatar
GET OFF MY LAWN
The SpeedSource cars down here have short primary into a borla muffler under the passenger seat area and another one in the stock location.
Old Nov 11, 2010 | 07:59 PM
wlfpkrcn's Avatar
Thank you sir. So I am not crazy.. maybe a little
Old Nov 12, 2010 | 11:02 AM
j9fd3s's Avatar
Community Builder
i think with mine i'm gonna go to the dyno with a sawzall, and start long and make it shorter until the engine and i are happy....
how long are yours? tested backpressure?
Old Nov 12, 2010 | 01:07 PM
wlfpkrcn's Avatar
I need to measure, but the header to the rear subframe. Not sure on the backpressure
Old Nov 12, 2010 | 05:53 PM
j9fd3s's Avatar
Community Builder
it LOOKS fine... if you put an 02 bung in there, its pretty easy to make a backpressure tester
Old Nov 12, 2010 | 07:17 PM
jgrewe's Avatar
GET OFF MY LAWN
There won't be much backpressure with that system in the picture but it would all depend on the muffler. I use a 6" piece of metal brake line brazed to the exhaust to hook up my magnahelic gauge. The brake line keeps heat from being an issue with the flexible hose to the gauge.
I first did this on an EP car that was running a Spintech muffler and was blowing 93db at the track. With the test port just ahead of the muffler the car pegged the 15"Hg gauge by the time the engine hit 4000 rpm. Not good, the muffler was like a potato. The new exhaust barely registers on the gauge and is, of course, a lot louder. It regularly registers 100-101db.
Old Nov 15, 2010 | 07:50 PM
wlfpkrcn's Avatar
Dynomax Muffler. Should not have much restriction
Old Nov 15, 2010 | 09:35 PM
j9fd3s's Avatar
Community Builder
yeah i think that muffler flows like 1100cfm or something....
maybe the primary length is off? i screwed mine up, but i wanted to do a slip fit, so i could just cut it and not have to reweld it back together... but its welded
plan B is to go to either midnight performance, or redzone, cause @midnight the dyno is above ground so you can build the exhaust ON the dyno...
Old Nov 16, 2010 | 03:34 PM
jgrewe's Avatar
GET OFF MY LAWN
I'll be at my friend's shop tomorrow and there happens to be a Speedsource exhaust laying on the floor... just need to find my spy camera...
Don49
Race Car Tech
Sep 3, 2015 05:03 PM
Engine stand ready
Comments and Suggestions Archive
Aug 28, 2015 11:59 PM
TerryD
Aug 23, 2015 07:40 AM
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
