Dumb Question: Replacing heater hose tommorrow, drain radiator?
Old Jul 1, 2002 | 07:28 PM
RarestRX's Avatar
NA Powah, Every Hour!
Yo,
I changed my oil pedestal o-rings, so now to change out the heater hose I think that's toast. This is the one under the oil filter going to the firewall. I assume I have to drain the radiator to do this. Right?
Thanks in advance.
KS
1989 GTUs "Kevin doing work on his GTUs?! Amazing!"
Old Jul 1, 2002 | 07:36 PM
j9fd3s's Avatar
Community Builder
you can either do that, or put something under the hose and hope you have good aim.
mike
Old Jul 1, 2002 | 11:24 PM
Scott 89t2's Avatar
SOLD THE RX-7!
well the easy way is to just pull the engine. Once it's out you might as well make use of all your work and stick a j-spec in. then get some real power outa that "race car"
Old Jul 1, 2002 | 11:27 PM
Sniper_X's Avatar
NO real NEED to drain, but just rinse off all the spilled 'freeze, its corrosive!
Old Jul 2, 2002 | 12:31 PM
SureShot's Avatar
Seduced by the DARK SIDE
If it's been more than a year since you flushed the system, now is a good time. (Mine is overdue)
streetlegal?
Mar 17, 2022 02:46 PM
sYnth.
Aug 19, 2015 06:27 PM
LMBTG
Aug 15, 2015 01:43 PM
