T56 to automatic fd bell housing
Old Nov 8, 2010 | 09:38 PM
rotorooter93fd's Avatar
YOUR TRIANGLE NIGHTMARE
Is anyone ever going to make on of these? Howard Coleman has been saying he would make one for 6 months now so that most likely isnt going to happen. If anyone else has made one I'm willing to pay 300 dollars to borrow it to copy the design. I would then return it and make copies for people and I would offer a cut of every unit sold plus the 300 dollars for letting me borrow their unit.
Old Nov 9, 2010 | 08:47 AM
patman's Avatar
Resident Know-it-All
I'm going to make one for a C4 ZF6 tranny if you would be interested in that, but I wont be finished for a couple months, and it will bolt right to a manual 13b block you wont have to get an auto rear iron.
Old Nov 9, 2010 | 09:31 AM
calculon's Avatar
On flats
I'd happily be a customer to anyone who could provide me a proven adapter plate/bellhousing machining package that would let me bolt my T56 to my 20B.
Old Nov 9, 2010 | 10:05 AM
If someone has one available there would be a good amount of money to be made simply by letting me borrow it to copy it and it would be returned immediately afterwards
Old Nov 9, 2010 | 01:04 PM
patman's Avatar
if someone wants to let me borrow their t56 for fitup i will make one. I was planning to go that route anyway, but I bought a "t56" from someone and had a buddy pick it up, and it turned out to be a zf6, so I'm thinking about using it instead. I could be persuaded the other way...
FYI I am lead engineer at a large fabrication shop with CNC waterjets and etc, so I can make things happen if I get interested....
Old Nov 9, 2010 | 01:17 PM
Rxmfn7's Avatar
Do a barrel roll!
Id like to get a hold of the 6-speed out of the 2011 mustang GTs. Its gear ratios are much more appealing to me than most any T-56:
Gear ratios
1st 3.66
2nd 2.43
3rd 1.69
4th 1.32
5th 1.00
6th 0.65
Final drive 3.31:1
I believe its a Getrag MT-82
Old Nov 9, 2010 | 02:08 PM
Rxmfn7's Avatar
Do a barrel roll!
^Patman are you able to do some side project like this at your shop? If you seriously have the equipment to make some adpaters and such there may be a project Id like to try if your pricing wouldnt be too much. PM me if youre interested.
Old Nov 9, 2010 | 02:14 PM
patman's Avatar
yes, part of my agreement is that i get to use company resources for my own **** if i want
Old Nov 9, 2010 | 08:20 PM
to_slow's Avatar
I got my bolt on kit from chipsmotorsports.com about a year ago. Very happy with the workmanship.
I don't think he will sell just the mounting plate, i asked a wile back..Quote people asking on the forum for them.
Hope it helps....
Old Nov 10, 2010 | 08:31 AM
calculon's Avatar
On flats
Hope it helps....
I went to the site and didn't see the kit. Any more info on it (i.e. - what the kit includes & its cost)?
Old Nov 10, 2010 | 08:34 AM
allrotor93's Avatar
i have an adaptor plate that you can copy. it mates an auto bell housing to the f body t56 if there is a difference
Old Nov 10, 2010 | 09:10 AM
calculon's Avatar
On flats
In terms of bellhousing bolt patterns, a T56 is a T56. Did you also have to have your bellhousing machined down to use this plate, or does it, by itself, ensure proper placement of the input shaft?
Old Nov 10, 2010 | 09:34 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
when i took delivery of the last iteration of the adapter plate i asked them for a price on 10.
since there probably aren't ten orders out there i will call them friday and ask for a quote on one unit and 5 units.
i am not going to do a group buy as i am far to busy but will be happy if anyone is interested to accomodate on a cash and carry basis. i have over one thou in developmental costs in the plate.
the adapter works perfectly although over the winter i am going to ditch the auto flex plate
(4.2 pounds) for an approx 12 pound custom Quartermaster flywheel.
the car leaves from a stop fine but i did have a problem w a stopsign that was on a steep incline.
i should have a price by monday. availability should be no more than 5 biz days plus shipping.
tha plate has no centering pegs so you need to use a dial indicator on the input shaft and center it prior to tightening the bolts. a 30 minute job.
as i mentioned from the getgo i built this for myself but am happy to share if anyone is interested. selling an adapter plate is a long way from job one for me.
i do love the conversion, it has worked out (including the clutch package) better than i had hoped. i am running 2200 pound springs in the clutch and will be back on the dyno this week to see how they hold.
since you guys make 50% more power you may want to up the spring pressure a bit. QM can give you whatever you want.
howard
Old Nov 10, 2010 | 10:19 AM
to_slow's Avatar
His site does lack allot of info.
Price wise I don't have it on hand, you might have to contact him directly.
But my kit came that I got from him, consisted of.
New reman starter
Machined bell housing
Stainless Steel adapter plate
Tilton hydraulic throw out bearing with willowood master
Tilton twin plate 7.25 rally clutch with with custom aluminum Fly.
Trans rear mount brace....
Hope it helps
Old Nov 11, 2010 | 02:18 PM
thank you Howard please let us know when you recieve any information as far as a price tag goes.
Old Nov 15, 2010 | 09:40 AM
olyrx7's Avatar
Please keep us posted
Old Nov 23, 2010 | 10:54 AM
calculon's Avatar
On flats
I contacted Chip ( chipsmotorsports ) about his offering and figured I'd post it here for anyone interested in pursuing it.
He said that the kit is made to order with a two (2) month wait.
The following breakdown is from the provided documentation.
Reman starter with machining to fit - $250
Adapter plate SS machined 3/8 thick - $600
7.25 Hydraulic bearing with post - $650
Machined bellhousing cleaned and prepped (customer provided) - $400
7/8 clutch master cylinder with bracket to fit FD rx7 - $156
Bolts, fittings/ss hydraulic lines - $130
Custom aluminum flywheel with Tilton twin plate 7.25 rally clutch - $2300
Total - $4600
to_slow, any chance we could see some pictures of your kit?
Old Nov 23, 2010 | 07:04 PM
to_slow's Avatar
Total - $4600
Yea his priced a bit high, From what he told me it a one off kit, Not to many people do t56 trans to a rotary.
But the quality of his craftsmanship and the fitment was second to none...
I don't have pics of the kit when I got it,, my drive crashed lost all the pics ..
Old Nov 23, 2010 | 11:31 PM
bewtew's Avatar
1BAD20B
$4600 for the kit? that's ridiculous!
i tried to put a kit together but i didn't have that many ppl interested..
Old Nov 24, 2010 | 07:47 AM
to_slow's Avatar
Originally Posted by bewtew
$4600 for the kit? That's ridiculous!
I tried to put a kit together but i didn't have that many ppl interested..
+1
Old Nov 24, 2010 | 10:03 AM
olyrx7's Avatar
how much mileage have you guys put on the t56 setup? At this time im just looking at the options but Im Just curious how long the tranny will hold at 700whp+.....?
Old Nov 24, 2010 | 11:47 AM
bewtew's Avatar
1BAD20B
if i have 5+ guys interested i would put a kit togheter after the holidays. it would not take long as i have done it before and i have pretty much another setup just sitting in my garage so i could just copy it AND it will not cost the rediculous amount of $4600.
olyrx7: i probably have about 2k miles of serious beating on the tranny and it's working fine. i had to drop my tranny to fix something stupid that i had going on with the clutch and i decided to open the tranny for inspection and every looked just like the day it was built.
Old Nov 24, 2010 | 04:05 PM
ReZ311's Avatar
KM48 Burnout
Add me to the list. Was looking at doing either a 2003+ viper trans or a newer built t56.
Old Nov 24, 2010 | 06:12 PM
Japan2LA's Avatar
I thought $4600.00 WAS CRAZY too..
Old Nov 24, 2010 | 07:55 PM
tony94s4's Avatar
Corn Fed FD
Gear ratios
1st 3.66
2nd 2.43
3rd 1.69
4th 1.32
5th 1.00
6th 0.65
Final drive 3.31:1
those ratio's look good but I wonder how strong it is?
ford stayed with t6060 for the gt500 instead of mt-82 on the gt
