My Rotary Miata
Old Nov 4, 2010 | 07:20 PM
rx7vargas's Avatar
Rotary Miata
Some photos of the rotary Miata I built. It has a 12a peripheral engine fully built with hardened racing parts took me a total of 3 months to build most of the time i worked on it was after college and the weekends
Old Nov 4, 2010 | 09:11 PM
theNeanderthol's Avatar
the torquinator
Awesome!! it's hard to see the induction system. Looks like a carburetor? What kind?
Old Nov 4, 2010 | 09:38 PM
Siraniko's Avatar
RX for fun
are you sure it is a P-Port? I see a glare of holley intake
Old Nov 4, 2010 | 11:44 PM
DiegoRx8's Avatar
if you look closely you can see the couplings. Also you can surely use a holley in a PP! lol
Old Nov 5, 2010 | 12:31 AM
turbo_dave's Avatar
#turbodavebuilt
Yupp it's a p-port,how can you miss that wacky.
Old Nov 5, 2010 | 01:17 AM
MountainScreamer's Avatar
Do you have better pictures of the engine bay?
Also what are you planning for suspension and such?
Really cool project tho!
Old Nov 5, 2010 | 08:29 AM
93rx74lyfe's Avatar
Ronald..
damn, if that was a 13b id say you have my ideal car.
Old Nov 5, 2010 | 12:45 PM
rx7vargas's Avatar
its a holley carburetor 650 ill put more pics of the engine bay soon
Yea its a PP running on a 650 Holley, for suspension i went with KYB GR-2 and lowering springs I'll post pics of the engine bay in a couple of mins
Here are some photos of the car now that its finished. I bought the car without an engine or transmission just a shell. I fully built the 12a with solid corner seal , super seals, racing springs, hardened stationary gears, stage II clutch, Front mnt intercooler, bigger radiator, dual electric fans, racing fuel pump, Mallory fuel pressure regulator, KYB's and the springs came with the car.
Still have a little bit to go i need to install a roll bar, hard top, wheels and slicks
Last edited by mar3; Nov 8, 2010 at 09:26 PM. Reason: Merged back-to-back posts...
Old Nov 8, 2010 | 09:28 PM
mar3's Avatar
Administrator
Cool little car...hang onto it and finish that puppy up, it looks like it found a good home.
Mario III
Old Nov 10, 2010 | 05:54 PM
arghx's Avatar
rotorhead
how does the engine feel compared to the factory piston engine? A stock 12A is rated at less hp than the Miata 1.6 liter. I guess a carb is simple and all but I would have done an s5 non turbo 13B engine controlled by a factory ECU.
Old Nov 28, 2010 | 05:45 PM
rx7vargas's Avatar
This isn't a stock 12a its Peripheral ported fully built putting out more HP than a stock s5 or a stock turbo II lol and it runs amazing no traction on second
having some problems tunning it does anyone know what size jets i should be using on a holley 650
Last edited by mar3; Nov 30, 2010 at 10:00 PM. Reason: Merged back-to-back posts...
Old Nov 28, 2010 | 07:35 PM
Bwek's Avatar
High Comp Booster
you have a front mount intercooler on your n/a car? with an 13b S5 front cover?
Old Nov 28, 2010 | 09:25 PM
lastphaseofthis's Avatar
My job is to blow **** up
Front mount oil cooler.
Last edited by mar3; Nov 30, 2010 at 10:01 PM. Reason: Killd quote since reply was back-to-back to post in question...
Old Nov 29, 2010 | 01:28 PM
rx7vargas's Avatar
Yea front mnt oil cooler sorry didnt notice that everything in there is from a 12a except the oil cooler, radiator, alternator, and water pump housing
Old Nov 29, 2010 | 05:36 PM
84stock's Avatar
looks like you have a holley 600 vac sec with the secondary diaphragm missing
Old Nov 30, 2010 | 03:17 PM
rx7vargas's Avatar
Yea i changed it today to a different carb that one was leaking air somewere , i installed a 750 that has the diaphragm on the secondary and race bowls running much better now chokes out when i pounch it but thats because i put # 71 jets for secondaries need to bring it down
Old Dec 1, 2010 | 09:14 PM
RobRX's Avatar
MADAZ
Good work
Old Dec 1, 2010 | 09:32 PM
84stock's Avatar
chokes out because your secondary spring is too light perhaps
Old Dec 8, 2010 | 03:25 PM
rx7vargas's Avatar
Video of the car the wheels are different now and the engine bay is way cleaner video is alittle old need to take a new one
http://www.youtube.com/watch?v=tVWWHbqpDWo
Old Dec 8, 2010 | 04:09 PM
jshiz's Avatar
Actin Like I'm Drunk
brap brap brap... good job. Can't wait till you finish it
Old Dec 10, 2010 | 05:41 PM
Radial GT's Avatar
*BOV sound*
Sounds like my snowmobile!!! I love it, very nice setup!
Old Feb 21, 2011 | 12:23 AM
rx7vargas's Avatar
Soooooo engine blew found out compression was escaping into the coolant system and i put in a turbo II 13b with a t04 t61 bridged, I'm working with the wiring to the ecu ,engine harness is done doing the side that goes to the coils, ignition, power, and gauges.
Old Feb 21, 2011 | 12:49 AM
infinite7z's Avatar
Noob Member
nice build!! what ecu are you running?
Old Feb 21, 2011 | 01:38 AM
wjk0817's Avatar
DD
I love miatas
I love rotaries.
Cool car bro
Old Feb 21, 2011 | 03:47 AM
yoeddynz's Avatar
Hell yeah- this is cool. It sits in there so nicely! It was meant to be eh?
Does the transmission tunnel have to be raised at all?
