TD61 @ 23psi
Old Oct 30, 2010 | 12:50 AM
Turblown's Avatar
Turn up the boost
TD61 @ 23psi
http://www.youtube.com/watch?v=1IGz6E1GBNI
Rotary Performance Parts
Old Nov 1, 2010 | 12:34 AM
arghx's Avatar
rotorhead
I feel the need... the need for speed!
Old Nov 1, 2010 | 04:11 PM
junito1's Avatar
F**K THE SYSTEM!!
What kinda fuel does this puppy run on because toque is NICE!!!!!
Old Dec 12, 2010 | 05:11 PM
Turblown's Avatar
Turn up the boost
It runs dual walbros...
Went out again....
http://www.youtube.com/watch?v=dQqsH1e763c
Old Dec 12, 2010 | 06:17 PM
junito1's Avatar
F**K THE SYSTEM!!
I meant as in fuel type.
e85?
Old Dec 12, 2010 | 07:58 PM
Turblown's Avatar
Turn up the boost
91 octane with water/alcohol
Old Dec 15, 2010 | 08:37 AM
ULOSE's Avatar
engine management?
Old Dec 15, 2010 | 08:19 PM
rotordad's Avatar
The Big Ugly!
Originally Posted by ULOSE
engine management?
At the begining of the Video it says Haltech E6K on pump gas.
Old Dec 18, 2010 | 10:30 PM
SpeedOfLife's Avatar
rotors excite me
passed that FB like it was standing still
Old Dec 21, 2010 | 12:24 PM
Nick_d_TII's Avatar
Nice. Looks like it goes pretty good...
I wanna drive on a track.
Old Dec 21, 2010 | 11:01 PM
Turblown's Avatar
Turn up the boost
Track takes a lot of work. Nothing like 10 minutes above 5k rpms at WOT.
We added a 3.5" midpipe/downpipe, a smaller Garrett FMIC, new bushings, an inconel LIM heatshield, and a few other goodies. Turbo also smoked itself running a turbo blanket that time around. What works on the street, doesn't always work at the track.. Going back soon for more fun....
Old Dec 22, 2010 | 03:50 PM
junito1's Avatar
F**K THE SYSTEM!!
the feedback that comes from the track is priceless.
And what do you mean by the turbo smoked itself with a turbo blanket..? IT ran hot because of the blanket and went kaput?
Old Dec 22, 2010 | 05:42 PM
2slow4stock's Avatar
The waiting game......
I am interested in how the turbo went out as well. By all the heat?
Old Dec 22, 2010 | 08:45 PM
Turblown's Avatar
Turn up the boost
Yes, the turbo blanket contains too much heat, and the turbo cooked itself. If you look around the single turbo section there are other people reporting the same thing. Turbo blankets were designed for diesel engines that run considerably cooler.
Old Jan 14, 2011 | 03:37 PM
BeauNC's Avatar
What A/R turbine housing are you using here?
Old Jan 14, 2011 | 10:21 PM
Turblown's Avatar
Turn up the boost
Its using a 1.15.
I wouldn't recommend that size for a smaller track like this on an FC engine, unless you have all your ducks in a row. As in; full ignition, big exhaust, divided turbo turbo manifold with the correct size tubing, and a engine with great compression.
We did a bunch more mods, going back out tomorrow. Got another FD we built going with too...
Old Jan 14, 2011 | 10:47 PM
BeauNC's Avatar
What do you consider a big exhaust?
What would you say is the proper sized turbine housing for a car that will see street duty, tight race tracks, as well as tracks like VIR with a 4000ft straight away?
I'm really liking this TD61 turbo from threads I've read.
Old Jan 15, 2011 | 09:19 PM
Turblown's Avatar
Turn up the boost
A 1.0 will work for most people. Its good up to 20psi, as long as you're not revving past 8k rpms.
That is what I would recommend for your needs also...
http://www.turblown.net/store/index.php?productID=65
Old Jan 16, 2011 | 10:18 AM
WannaFD's Avatar
I must say, I'm vary impressed with those dyno number on pump gas even with the water/alcohol injection. Thats one hell of a tune
By the way, seen the video of your Rx-8 on streetfire yesterday, great job on that as well!
Old Mar 2, 2011 | 04:58 PM
TheAbsence's Avatar
s4 Pride
rofl, then late braked the Mini. I lol'd.
Old Aug 10, 2011 | 12:32 AM
Moose.Knuckle's Avatar
sweet ride
Old Aug 10, 2011 | 08:09 AM
hatemy7's Avatar
Rotary
That thing is sick!!!! Seriously, the throttle response is no joke
