downpipe and catback is all right?
Old Jul 1, 2002 | 11:23 AM
MazdaMike's Avatar
ok this is one of those dumb *** questions but bear with me. i heard that it is recomended to get an a/m eco if u change ur midpipe to a high flow. my question is, if i was to instal a downpipe and a high flow cat back would that replace the midpipe(and its catylic converter). and if it would does that mean i have to get an a/m ecu?
also on a side note, what are your opinions on the best high flow cat back, i am looking for one where u can hear it rumble but not the obnociously loud coffie-can rice boy ones. something subtle but can mak some noise. not to big either
Old Jul 1, 2002 | 11:29 AM
Street King's Avatar
*** Bless Texas!
No a down pipe takes car of the pre-cat, cat back takes care of restrictive muffler, mid pipe takes care of main cat. You dont need an ECU upgrade until your pushing past 12 psi which you need a boost gauge to tell you that. A cat back and downpipe is fine and you could probably get away with an intake with a boost controller.
Old Jul 1, 2002 | 11:43 AM
ttpowerd's Avatar
HARRRRRRRRR
As long as your not over 12 psi you are fine on the stock ecu. Definately get a boost gauge. If you replace your "cat" with a hi flow cat then you will be fine. Don't replace it with a midpipe till you have ported the wastegate and/or gotten a new ecu.
Old Jul 1, 2002 | 09:53 PM
MazdaMike's Avatar
k thanks yea august 1st i bring her in to kdr well see what dave can do for me
Old Jul 1, 2002 | 10:02 PM
Quickfini's Avatar
Yeah i've got a dp and cb and no problems here yet..
Old Jul 1, 2002 | 11:04 PM
MazdaMike's Avatar
k thanks
Old Jul 2, 2002 | 12:50 AM
turbojeff's Avatar
Do it right, do it once
make sure you don't get any boost spikes with a DP and CB. Every car is different, some get it and some don't. Enlarge the size of the WG pill to reduce/eliminate spiking if you have it.
Jeff
Old Jul 2, 2002 | 01:11 AM
Missing my pistonless car
I heard someone say an ECU is necessary with a "3" mod rule? I guess that doesn't apply?
I'm not planning on turning up the boost, but would a more efficient intercooler require an ECU upgrade?
Old Jul 2, 2002 | 11:05 AM
ZeroBanger's Avatar
I have an rx7fashion highflow cat and its great.
Old Jul 2, 2002 | 11:12 AM
ttpowerd's Avatar
HARRRRRRRRR
3 mod rule is bogus! As long as you are not spiking or creeping then you are fine. Keep your boost as close to 10psi as you can and you should be fine. Don't get too carried away though because you will spike unexpectantly and then "pop"! It is always a good idea that after a few mods you upgrade your ecu as a safety measure (eg. intake, cb, dp, pulleys, possibly an ic but that is stretching it)
Old Jul 2, 2002 | 12:52 PM
MazdaMike's Avatar
ok yea i dont know what to do about an ecu, i cant tune on my own. any suggestions on one to get?
Old Jul 2, 2002 | 12:53 PM
ttpowerd's Avatar
HARRRRRRRRR
pettit or m2!
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
