Megasquirt strange problem car shuts off
Old Sep 26, 2010 | 02:45 AM
gabs88gxl's Avatar
Retard
SO heres the problem its weird. So what happens the car will start n idle. If i start to move the car it will dye. Then it wont start agian. Ill move the ms like grab it an move it. its just sitting on the floor right now. The car will start agian. an i can drive it all over. But If i grab the ms well the car is running an move it it dies or turn it over like upside down it dies. I went threw all my wires an there all soldered an tight.
Also i soldered a new db37 in an the same thing. The male part of the ms i even opened up the tips of the pins so that it would make a tighter connection in to the female connecter. Still the same thing. I dont know what it could be i hope this makes sence ill post a datalog tomorrow
Old Sep 26, 2010 | 10:05 AM
Aaron Cake's Avatar
Engine, Not Motor
Sounds like you have a bad connection on the board itself. Cold solder, cracked trace, etc.
Old Sep 26, 2010 | 02:12 PM
gabs88gxl's Avatar
Retard
Humm ill have to check it out now. Im going out side to play with her so ill let u know,
Old Sep 26, 2010 | 05:24 PM
gabs88gxl's Avatar
Retard
ok so i went threw the board tapped everything with the iron. Put it back in an it seems to have worked. I grabbed the box moved it shook it moves wires around so far still good stayed running. Im hoping this was it knock on wood thanks aaron u the man.
Old Sep 27, 2010 | 02:33 AM
gabs88gxl's Avatar
Retard
so far so good. Drove it all night long started up everytime. Pretty sure i got it thanks again aaron.(knocking on wood) lol
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
gtcd
30
Aug 19, 2015 02:44 AM
