Megasquirt BAC question
Old Sep 22, 2010 | 02:24 AM
gabs88gxl's Avatar
Retard
BAC question
I have my bac on my tii on the uim. But my main question is what i have to do to the bac to make it work as of right now i have the bottom port blocked do i have to have that open or no. Im pretty sure the bord is set up ro run the stock bac. I bought it an went threw an everything checked out to run the stock bac.
Old Sep 22, 2010 | 10:13 AM
muythaibxr's Avatar
MegaSquirt Mod
You need to take off the vacuum cap, connect +12v to one pin on the BAC, and the other to the circuit on the v3 board (assuming it is set up for the BAC).
Ken
Old Sep 22, 2010 | 04:04 PM
Aaron Cake's Avatar
Engine, Not Motor
And make sure to run that uncapped port to a source of filtered air.
Old Sep 22, 2010 | 05:00 PM
gabs88gxl's Avatar
Retard
im running the 2.2v board with the stuff to do it me an aaron talked about it a few weeks ago he said i can do it but its a pain to get it right. But aaron by filtered source like put a little filter on it like a breather or to my air filter. right
Old Sep 23, 2010 | 09:16 AM
Aaron Cake's Avatar
Engine, Not Motor
You can just stick a breather filter on it, but then you have to put up with the massive sucking sounds the valve will create in operation. So I'd suggest running a tube to your TID/air filter.
Old Sep 23, 2010 | 02:40 PM
gabs88gxl's Avatar
Retard
ok im going out side now to work on it. Ill give it a shot for now im just going to put a breather on it cause im not really driving it very much. Cause im trying to clean everything up under the hood. But thank you aaron N ken.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
