Is there an easier way to take out the studs?
Old Jun 29, 2002 | 01:05 AM
c00lduke's Avatar
I just got in a shippment of block off plates but i didn't relize how much of a PIA getting all the little studs was going to be. Has anyone done this and found and easier way. I'm maily talking about the ones on the LIM.
Thanks
~Luke
Old Jun 29, 2002 | 02:42 AM
duboisr's Avatar
put two nuts on the stud and tighten them together very tight then put your tool on the bottom nut and turn . The stud should back out . If you hit the end of the stud sharply with a hammer it will help ,this hit is referred to as setting the threads.
Old Jun 29, 2002 | 11:14 AM
Ed Everidge's Avatar
If you are willing to replace the stud, attach a single nut with red locktite.
ls1swap
Jun 3, 2024 03:25 PM
toplessFC3Sman
Mar 20, 2018 01:54 PM
