Thermal Flex radiator hoses
Old Jun 28, 2002 | 02:44 PM
CYM GIRL's Avatar
Question Thermal Flex radiator hoses
Has anyone ran into problems with these radiator hoses? I want to replace my upper and lower radiator hoses on my FD, but I don't want to run into problems using these hoses. Any feedback would be appreciated.
Thanks
Old Jun 28, 2002 | 05:13 PM
Sled Driver's Avatar
The Anti-Prius
I have a set from the group buy.
The "Thermo Flex" logo on the upper hose was printed on the side facing the airbox, so you cant see it.
The lower hose has the logo printed on both side, only they are printed upside down
Other than that, they kick *** & look great. You should get the special hose clamps with them. Standard clamps will score/cut the hoses.
They are supposed to be stonger, but I thought they looked cool, being red & all
Does this help?
Old Jun 28, 2002 | 05:54 PM
hapa's Avatar
I bought a set as well. They are excellent hoses, 4-ply silicon construction. At the price they are the best hoses out there. The Samco hoses are the only ones close, and I believe they are only 3-ply and they cost $50 more, if you can find someone that stocks them.
eric
btw thermal flex recommends any stainless steel "constant torque" clamps.
Old Jun 28, 2002 | 06:18 PM
itrdanny2001's Avatar
I was very happy with my red set. The aesthetic value is what i bought them for, but they are much better than the O.E. hoses. They look great as long as you keep them clean.
The only thing that was a bit of a problem when I ordered was the wait time. My hoses came in two weeks late and the order wasn't correct. I'm sure that was just a fluke though. The customer service was pretty good.
Old Jun 28, 2002 | 08:46 PM
GoRacer's Avatar
Speed Mach Go Go Go
Wink CYM girl ,where ya been?
I bought a blue set on the group buy. I don't remember any logo on them? They have a slight purplish tint to them but you could get yours in yellow. I have regular stupid Mazda clamps
They are an exact copy of the OEM so there is no fitment issue.
If you really want to get really fancy then get the FEED braided stainless steel ones.
http://www.jt-imports.com/U.S.Atop.htm
http://www.pac-gate.co.jp/feed/fd3s-fe.html
Oh yeah, Where's the pic of you and your CYM you were gunna post?
Old Jun 29, 2002 | 02:17 AM
Lunar7's Avatar
Those hoses are great.
I ordered a set in black for a stock look.
Not that you can really see them anyways.
Only issue is that they are a bit longer than stock.
I had to trim both ends of the lower hose to keep it from kinking.
They trim easily with a razor blade.
Definetly get 4 of the constant torque clamps in the 27-51mm size. They clamp well and won't tear up the silicone.
I recommend removing the abrasion sleves from the stock hoses and installing them on the silicone hoses. That will provide extra protection from any possible abrasion damage.
I also noticed that they don't shed rubber residue like the stock hoses did. The coolant stays clean and residue free.
Old Jun 29, 2002 | 04:15 AM
Blackbeast's Avatar
Thermoflex Radiator Hose
For those of you with Thermoflex upper radiator hose and Greddy pulley kit, does the hose clear? If Thermoflex is stronger, I assume it's "thicker" than OEM radiator hose?
Can some one fill the spot light on this because my greddy pulley kit already come VERY CLOSE touching the upper OEM radiator hose.
Tx.
Timmy
Old Jun 30, 2002 | 01:42 AM
CYM GIRL's Avatar
Thanks for all the response. I have to look into the Feed radiator hoses.
I completely forgot about the pic, I'll try to get it scanned this week.
