Canadian Forum Canadian users, post event and club info here.
gt35R single turbo conversion cost? pros n cons
Old Sep 7, 2010 | 11:41 AM
anees's Avatar
amemiya7
hi
so i was wondering how much would it cost to take out the stock twins and upgrade to single turbo
i donot have the funds rite now
its just a thought.. so what you guys think about the single turbo conversion and how much will it cost me?
thanx
Old Sep 7, 2010 | 02:30 PM
2Fierce's Avatar
Cautious Angel
5kish
You need to upgrade your fuel, your ignition, and the ecu/gauges.
Intercooler/rad if you haven't upgraded.
Then you need the actual turbo, manifold, wastedate, downpipe, exhuast if you don't have one, lines, just search the single turbo conversion section. There are a lot of threads of people "going single" builds to see what they did.
+ Labour if you aren't going to do it yourself...
Old Sep 7, 2010 | 05:01 PM
Zhé's Avatar
raawwwwrf
+ tune
Old Sep 7, 2010 | 05:43 PM
thewird's Avatar
I'd say more in the range of be ready to spend close to 10k for a stock FD, start to finish to not do a hackjob. It's not cheap but highly recommended due to better reliability and less engine bay heat. To get you an idea...
35R single turbo kit (Can range from $2,500 to $3,900) new
Powerfc ($800-$1000) + tune ($350-$400)
blow-off value (varies)
Greddy elbow ($140 new)
Upgraded Aluminum Radiator ($300-$400)
Intercooler (varies)
denso/supra fuel pump ($210-$300)
Fuel System (rail(s), injectors, FPR, lines, fittings, injector clips) ($580 - $1050)
hks twin power /w plugin harness ($420-$500 new)
boost controller (varies)
aftermarket clutch (varies)
block off plates ($50-$80)
oil catch can (varies)
spark plugs (oem 9's or something like the greddy racing plugs)
highflow cat or midpipe (recommended)
Rewire fuel pump directly to the battery with a relay
Possibly:
fuel pump filter if never changed
If you only have 1 oil cooler, you need to upgrade to dual R1 oil coolers or aftermarket duals
Water injection kit (not required but highly recommended)
Some gauges (fuel pressure or wideband recommended at least)
aftermarket exhaust if still stock
Of course there is shipping + customs if ordered from the states or inflated Canadian prices + tax. And the cost of labor to install it all which is going to be in the $1,000-$2,00 range at least going from a stock FD unless you do it yourself. That's all I could think of, off the top of my head, there might be other little things missing.
Not meaning to be a downer but you need to be prepared.
thewird
Old Sep 7, 2010 | 06:00 PM
Double_J's Avatar
That's a good list. I say buy my FD it puts out similar power to a small single and has much better response.
Old Sep 7, 2010 | 07:34 PM
HalifaxFD's Avatar
GT3574R equipped
it all adds up pretty quick.
Old Sep 7, 2010 | 11:42 PM
Zhé's Avatar
raawwwwrf
pros:
more power
more reliability
cleaner engine bay
cons:
cost
Old Sep 8, 2010 | 05:04 AM
2Fierce's Avatar
Cautious Angel
I predict his FD goes up for sale after this thread lol
Old Sep 8, 2010 | 06:03 AM
Double_J's Avatar
Cons
Cost
Response
If you keep the rpm's up the car is quick but you can't beat sequential twins for just semi spirited driving around town.
Old Sep 8, 2010 | 09:06 AM
anees's Avatar
amemiya7
Possibly:
thewird
thanx a lot for your detailed info
i was wondering if gt35R is the rite turbo or i have more choices in similar price range?
Old Sep 8, 2010 | 10:41 AM
Ironstoke's Avatar
Hey Anees, what type of ecu do you have again?
Old Sep 8, 2010 | 12:09 PM
anees's Avatar
amemiya7
rite now i have KSP knight sports ebs111? why tho?
Old Sep 8, 2010 | 12:23 PM
thewird's Avatar
Well, what do you want out of a single conversion, power or response? The 35R is basically the entry level turbo for an FD (anything smaller doesn't make sense) as it provides good response so you don't notice the additional time it takes to spool compared to twins.
Similar turbos would be the Precision billet 6265 which also has a 62mm compressor and should actually make more power with similar response. Price range for a kit from A-spec for example would be $2275 for non-ball bearing and $2950 for ball bearing. The billet 6265 is the best bang for the buck imo.
thewird
Old Sep 8, 2010 | 12:56 PM
2Fierce's Avatar
Cautious Angel
That price does not include shipping, customs, tax or conversion rate....it's a lot more than people think.
Old Sep 8, 2010 | 03:11 PM
thewird's Avatar
Of course, and that's with a dumped wastegate as well so if you want your wastegate plumbed back into the exhaust it would be more.
thewird
Old Sep 8, 2010 | 03:15 PM
2Fierce's Avatar
Cautious Angel
+ coating, or exhuast wrap...and ducting.
sherff
Feb 24, 2019 12:09 PM
