Starter Does Nothing ! ! ! ! Did search (Nothing)
Old Jun 28, 2002 | 11:05 AM
CantGoStraight's Avatar
What's your point ?
Well went to the weekly car meet last night. Stopped by Mickey D's and got dinner, pulled into parking lot left the car & A/C runing ate dinner. After eating I shut the car off went to rest room and when I returned I had coolant on the ground. (no big deal been coping with an O-ring problem) wated around awhile and decided to go get a drink. Put key in pushed in clutch and turned it to start the car......NOTHING no click no buzz NOTHING. checked fuses none blown, suaspect clutch switch but not sure yet....could it be the starter it self. Battery is less than a year old so I need to know if any one else had this happen and what they found. Only have stock alarm and not boost controller. Help appreciated, Jack
Old Jun 28, 2002 | 11:50 AM
Mine is having a intermittent start problem, that is smilar. If I listen carefully, I do hear a relay click when I turn the key to start. I am very suspicious that it is the starter solenoid. If all your lights are not dim when you start, try metering the start wire on the starter when someone turns the key to start. If you have power there, it's definately something in the starter.
J
Old Jun 28, 2002 | 02:32 PM
What's your point ?
Thanks Yellowbird,
I'll pull the starter and have it checked then go from there. I was hoping someone already had this problem and and could tell me what it may be for sure. Jack
Old Jun 30, 2002 | 08:46 AM
What's your point ?
No one has a clue
I can't believe no one else has had this problem where there car wounldn't start without any symtoms or indication there was going to be a failure ? ? ? ?
Old Jun 30, 2002 | 09:54 AM
kidzip's Avatar
starter problems
check your starter switch at the pedal. I'll put my money there. It happened to me.
Old Jun 30, 2002 | 10:45 AM
What's your point ?
Start problem intermitten
Well following the logic it broke on it's own and it'll fix it self on it's own seemed to work. I went out to start the car (sitting two days now) and it acted like it was going to contiue on without starting. i only turned the key on one time it hesitated and then jumped to life.....switch, bad starter, still to be determined. Thanks for the replies, Jack
manoflego
19
Sep 30, 2015 05:19 AM
series1rx7
Sep 27, 2015 05:46 PM
Boans
V-8 Powered RX-7's
Sep 25, 2015 04:34 PM
Devon Murray
Sep 25, 2015 09:41 AM
subeone
Sep 24, 2015 09:58 PM
