thermowax question
Old Sep 2, 2010 | 03:25 PM
BlackRexx7's Avatar
thermowax question
Can the thermowax cause a lean idle AFR if it isn't working properly?
Old Sep 2, 2010 | 03:28 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Thermowax does not affect mixture at all. It only increases idle speed when cold. What makes you think the mixture is lean at idle? If this is an S4, the variable resistor can be used to adjust mixture and smooth out the idle.
Old Sep 2, 2010 | 03:48 PM
BlackRexx7's Avatar
me and my brother's friend were discussing components on the throttle body and i was curious if it would lean out the mixture at all because he is having problems with his car running lean. actually would anything on the throttle body cause this? lol
Old Sep 2, 2010 | 04:11 PM
Top Down, Boost Up
The TPS does.
Old Sep 2, 2010 | 04:33 PM
RotaryEvolution's Avatar
Sharp Claws
so can vacuum leaks.
Old Sep 3, 2010 | 01:54 PM
BlackRexx7's Avatar
yup. Well we checked all that stuff on his car and didn't find anything wrong. but when we checked the pins on his ecu we found a few things.
well quick question, if the IAT sensor on the engine has a higher voltage at the ecu pin then its supposed to (like 3v instead of 1-2) on idle when its fully warmed up, would that make it run lean?
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
