does any company make a skinny
Old Sep 1, 2010 | 02:20 PM
cyipher's Avatar
does any company make a skinny wheel 15x4 that will clear a TII 4 piston caliper without spacers... Ive tried billet specalities and weld with no luck and I'd perfer not to have a custom wheel made...
Thanks
Old Sep 1, 2010 | 02:35 PM
Raid3n's Avatar
diamond racing wheels if you dont need them to look pretty
Old Sep 1, 2010 | 02:37 PM
Nick_d_TII's Avatar
I'm not sure what the size of the spare is, but I believe its an enkie and could possibly be used as a skinny...
Old Sep 1, 2010 | 05:09 PM
cyipher's Avatar
the car go's 150-160 in the quarter i want something that will hold up at those speeds. good idea though for the budget minded racer.
SpeedOfLife's Avatar
rotors excite me
Yeah I know some guys just use the spares as noted ^^^
I've also heard some of them just sand the speed warnings off the stock spare rubber and run it down the strip anyway
edit: 150+? hmm...
Old Sep 1, 2010 | 05:21 PM
Nismo Convert86's Avatar
400WHP or bust
Put Motorcycle tires on it, or get these to replace the stock doughnuts.
http://www.mickeythompsontires.com/s...p?item=ETFront
Old Sep 1, 2010 | 07:23 PM
cyipher's Avatar
edit: 150+? hmm...
yeah cars a first gen rx7 with the tII brakes, ran a 9.46 at 149ish and im not done adding power yet
Old Sep 1, 2010 | 09:27 PM
sen2two's Avatar
Rx2 > FD
the stock spare as pictured above works great with a nice Moroso, Coker, or MT skinnie tire on it.
You can also have your brake rotor machined down to fit the smaller brake caliper and then and weld wheel (or similar) will fit with no problem. Braking is still fine, Theres a few V8 FC guys that have done this.
The only other way is to either use an adapter, or use longer wheels studs with spacers. Plenty of people do that and are running in the 8's. It's perfectly safe.
Old Sep 1, 2010 | 09:39 PM
durtled's Avatar
now seeing that car i wanna hear it not not using a v8 are u?
Old Sep 1, 2010 | 10:09 PM
Jimmy2222's Avatar
+1 same, sorry I'm not really adding to the thread. I'd just like to see it.
Old Sep 2, 2010 | 02:45 AM
cyipher's Avatar
Do you have any more info on this?
Old Sep 2, 2010 | 02:27 PM
sen2two's Avatar
Rx2 > FD
I cant remember exactly. But i'm 99% sure you just have to turn down the diameter to the smaller rotor diameter from the 4 lug FC. Then just bolt on the smaller calipers from the 4-lug 2nd gen to your 5 lug car.
Old Sep 2, 2010 | 03:25 PM
cyipher's Avatar
are those spares 15's or 16's?
Old Sep 2, 2010 | 05:28 PM
Nick_d_TII's Avatar
looks like 15". they're cheap on ebay...
http://cgi.ebay.com/ebaymotors/ws/eB...d=310244086846
http://cgi.ebay.com/ebaymotors/88-89...Q5fAccessories
Old Sep 3, 2010 | 12:13 AM
daviddeep's Avatar
Rotary Powered Since 1995
Most of the ones on eBay now are the 4-lug version. You can usually find the five-lug one for about the same price. The 5-lug is a 16" while the 4-lug is a 15". I know the 5-lug is 4" wide because I have a couple.
Old Sep 3, 2010 | 04:34 AM
teddyrx2's Avatar
One Luv "Till The End"
I have first gen SA running those turbo II spares with skinnies on them...I don't have the Turbo II brake up grade up front...
But as mentioned before you can have the caliper machined so they can take excess material off...Or the other way is to buy longer studs, use open end lug nuts, and use a spacer for clearance...You will be fine...I have pics in the old school section on the last page of my car...
the Four lug spare is a 15 incher
The 5 lug spare is 16 incher
Old Sep 3, 2010 | 10:07 AM
cyipher's Avatar
I found a wheel that will work and looks awesome. Here it is in 8" wide but the manufacture says the center sections are the same for the 4 and it clears fine all the way around.
Old Sep 22, 2010 | 01:16 PM
ryans1000's Avatar
To save the trouble or have more rim options could you just go 16" . Is there that big of a weight savings on doing a 15 over just a 16" front rim or is there another reason to go 15"
Old Sep 22, 2010 | 01:21 PM
cyipher's Avatar
Here they are...
cyipher's Avatar
most racing skinnys are 15 or 17
Old Sep 22, 2010 | 01:29 PM
ryans1000's Avatar
Thanks cyipher . Yea i browsed online and just noticed tire options for 16's are not great. what series/model is that weld rim you got to work? link? and do you know the offset.
Old Sep 22, 2010 | 01:33 PM
ryans1000's Avatar
i was hoping to buy this rim fast five front SUM-521-5465PS http://www.summitracing.com/parts/SUM-521-5465PS/ but sounds like my chances of that fitting are not good??
Old Sep 22, 2010 | 01:46 PM
cyipher's Avatar
Those are the weld RTS wheels P/N 71MB-504A15A
http://www.summitracing.com/parts/WLD-71MB-504A15A/
Old Sep 22, 2010 | 02:15 PM
cyipher's Avatar
I can tell you cause i had those exact rims, that the DO NOT fit with out a spacer or grinding on the wheel.
Old Sep 22, 2010 | 11:13 PM
ryans1000's Avatar
cyipher, what front rim are you running in that picture in post 7? the weld rims are really nice although saving money and going with the rx7 spares are tempting. How fast have people went on that spare rim or what is it rated for?
