low transition boost need some help.
Old Jun 28, 2002 | 12:53 AM
violator's Avatar
i get 12-5.5-12 boost pattern. checked my pipes for leaks and none found. did a search and peeps say something about a prespool valve? got ne pics to help me fix my damn transition. hehe thanks
also not on this topic but will the PFC control boost? or do i need the boost controller kit from apexi? i have the boost controller kit but dont know if i need to install it or not.
Old Jun 28, 2002 | 06:47 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
could be a few different things
1) might be your TCA (Turbo control actuator)
This quickly opens using vaccume AND pressure to add the secondary to the primary (exhaust side). If you are not gettin vac or pressure to one sode of the acctuator then it will open slowly and may cause a larger dip.
2) might be your Turbo Pre-Control actuator
this opens at 3.5 rpm and diverts exhhaust to the secondary to pre-spool it, if it is not opening then the 2ndary dosnt get prespolled and take a second to get up to speed, thus a larger dip.
If after transition it is slow to rise back to 12 then its prob not gettin pre-spooled. If transition is quick and jumps back to 12 then its probably tca opening slow?
Just a guess....
Old Jun 28, 2002 | 09:33 PM
violator's Avatar
yea its pretty slow. cuz when the transition drops to 0.4 bar i feel the dip big time. its like a huge lag then it builds the boost again. where do i adjust the Turbo Pre-Control actuator? can u gimme a pic? also if i crank up the prespool too much what will happen? thanks
Old Jun 28, 2002 | 11:48 PM
poss's Avatar
Slower Traffic Keep Right
I don't think that the TCA is adjustable, or at least would benefit from adjustment. I have a similar problem, but i think i must have a cracked vacuum hose somewhere that is leaking vacuum or pressure. i'm doing a vacuum hose job pretty soon to see if that helps. as far as your pre-spool, too much will give boost spikes, too little will give unnecessary lag.
Old Jun 30, 2002 | 05:09 AM
violator's Avatar
^^^ damn i hate this boost leak ****. if i cant fix it im just gonna go non-sen
Old Jun 30, 2002 | 05:01 PM
Pumped's Avatar
just go non sequential
Queppa
Nov 18, 2024 03:47 AM
HDA
Nov 3, 2015 03:49 PM
