Information on Injector Dynamics ID725/ID1000/ID2000 drop-in fitment for stock rails
Old Aug 30, 2010 | 03:22 PM
arghx's Avatar
rotorhead
I just finished exchanging a bunch of emails with Injector Dynamics. As some of you may know, Injector Dynamics sell high impedence injectors nominally rated at 725cc, 1000cc, and 2000cc while being based off the recent Bosch EV14 design.
On the ID website you can order "direct fitment" parts. Here it is for the ID2000: http://www.t1racedevelopment.com/en/...-set,rx-7.html
You want to select the 11mm top in order to drop right in to the factory rail. The 11mm injectors are blue:
When you order "direct fitment" you should receive a cushion so that the injectors will seal properly on the bottom:
The cushion is used instead of the normal 14mm o-ring you would find on say the older Bosch 1680cc injectors. This cushion is also available separately under the fuel delivery-->connectors and accessories section of the site. Here is a pic they provided of how the cushions look when installed (you would not be using a black injector):
For those of you with aftermarket Bosch style rails (such as the KG rail), you want the 14mm top purple injectors:
These will also use the cushion at the bottom to seal properly. For the injector connectors, the ID725 and ID1000 use a Bosch EV6 style connector (also labeled "USCAR")
The ID2000 uses a Denso style connector like you would see on a lot of Hondas:
Attached Thumbnails Information on Injector Dynamics ID725/ID1000/ID2000 drop-in fitment for stock rails-id2000-60-11.jpg   Information on Injector Dynamics ID725/ID1000/ID2000 drop-in fitment for stock rails-denso-cushion-installed.jpg
Old Aug 30, 2010 | 03:28 PM
rotarygod's Avatar
Rotors still spinning
Paul Yaw has some pretty awesome injectors with those pieces. Every other injector on the market is literally 25 years behind in technology.
Old Sep 6, 2010 | 12:48 AM
-==L=a=N=c=E==-'s Avatar
i wonder if 4xID2000 injectors would be too much for the stock fuel rails?
Old Sep 6, 2010 | 01:06 AM
MaczPayne's Avatar
Mac Attack
Thinking about getting a set of these for my next build, great information!
Old Sep 6, 2010 | 03:59 AM
J-Rat's Avatar
Alcohol Fueled!
I loved those injectors and I recommend them to ANYONE.
Old Sep 6, 2010 | 10:09 AM
Slammedblk7's Avatar
Yes its slow
Im running 4xID2000 injectors on KG rails. This is good info! As I had to learn on my own, I needed the purple tops. Now they fit like a champ!
Old Jun 4, 2013 | 04:54 PM
TainoCo's Avatar
S366 is my Haven
Great Post and Good Info...
I have one simple question if anyone could help me out...
Currently running PFC with resistors for my low impedence injectors.
Primaries 1000cc
Secondaries 1600cc
Primaries are bad but going with ID 1000cc Blue Top's...
My question is:
Since my current setup has resistors for low impedence injectors, would ID 1000c High Impedence Injectors be of any trouble or would the resistors need to come off for the ID's???
Old Jun 4, 2013 | 10:18 PM
eage8's Avatar
1308ccs of awesome
Primaries 1000cc
Secondaries 1600cc
My question is:
the resisters need to come off.
Old Jun 5, 2013 | 12:00 PM
TainoCo's Avatar
S366 is my Haven
Much appreciated!
Old Mar 24, 2014 | 11:23 AM
Black7Conv's Avatar
Great info! just wondering, I have 2x SARD fuel rails and upgrading to ID injectors, Do i need the 11mm or the 14mm ones?
thanks!
Old Dec 25, 2014 | 10:10 PM
island fd's Avatar
thanks!
I'm wondering the same, did you get an answer?
Old Dec 26, 2014 | 09:37 AM
Black7Conv's Avatar
No, so one day, took the SARD fuel rails off and measured them.. so the answer is 11mm ID injectors.
thanks,
George
immanuel__7
Megasquirt Forum
Aug 22, 2015 09:34 PM
eddierotary
Aug 16, 2015 04:12 PM
