Removing CAS
Old Aug 28, 2010 | 02:25 PM
1sick13b's Avatar
Removing CAS
How in the world do you remove the CAS, I took out the 10mm bolt and unplug the harness. Dont I just pull it out? This thing is like siezed!!!
Old Aug 28, 2010 | 08:32 PM
Innovation's Avatar
It should just pull right out. Make sure the timing marks a lined up properly. I just pulled mine to replace the front cover gasket and I had to pull out and push up a little and it popped right out.
Why are you removing the CAS?
Old Aug 28, 2010 | 10:31 PM
misterstyx69's Avatar
Retired Moderator, RIP
The cas has a small o ring that surround the shaft.
it is then placed in the front cover and bolted in place with that 10mm bolr.
What happens is Corrosion will set in there and make the Cas hard to Remove.
By taking the 10 mm bolt out and Tapping on the Cas casing,you should be able to eventually break it free and pull it straight up and out.
try and hit it from Under the Casing,It is a hard place to get at,but Trust me it works every time.
Old Aug 29, 2010 | 01:36 PM
dexter_5000's Avatar
make sure to use some never-seize when re-installing it.
Old Aug 29, 2010 | 09:29 PM
1sick13b's Avatar
Thanks ill try tomorrow and Im taking it out to put a 1st gen dizzy Im running mikunis sidedrafts
NEWGENRX7
Jun 26, 2019 12:20 AM
Steelwheelz
Sep 15, 2015 03:22 PM
