Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
Renisis exhaust porting?
Old Aug 25, 2010 | 10:40 PM
Jimmy2222's Avatar
Hey guys, just curious, no real meaning to this post. But, has anybody ever messed with exhaust ports on a Renisis? They are side ports, would you be able to do a bridge on the exhaust side?
Old Aug 25, 2010 | 10:58 PM
pluto's Avatar
you shouldn't bridge the exhaust port because of the exhaust sleeve
Old Aug 25, 2010 | 11:08 PM
Chuck Norris FB's Avatar
IL
I have been thinking about this as well,but i think it's preferred to port the side exhaust in a downward direction too open it sooner. there is plenty of meat to do so,however doing a exhaust bridge would make the engine lose it's zero overlap
Characteristics and may lose H.P
Old Aug 25, 2010 | 11:15 PM
Jimmy2222's Avatar
Yeah, thought exhaust would be interesting on these. For a high revving N/A motor, would peripheral port's be preferred or would side ports perform better?
Old Aug 25, 2010 | 11:30 PM
IL
Are you referring to the intake or exhaust ports? of the renny.
Old Aug 26, 2010 | 01:10 AM
Jimmy2222's Avatar
Just in general for high revving application rotaries
Old Aug 26, 2010 | 01:51 AM
ArmyOfOne's Avatar
Bridge Port Freak
It may look as though there is a lot of meat to port down but what you dont see is that there is a water passage running through that meaty piece. And as for BP on the exhaust it will quickly overheat the bridge and it will crack at the most inopportune time. There is some porting but exhaust is a very touchy part of the system for this engine.
Old Aug 26, 2010 | 10:10 AM
rotarygod's Avatar
Rotors still spinning
You can't bridge the exhaust port of a Renesis. The water jacket is shaped very weird here and believe it or not extends between the exhaust sleeve and the face of the housing in this area. It is only an 1/8" wide or so but it is there. If you try to bridge port it, you'll cut into the water jacket. Due to the shape of the water passages, even porting the exhaust ports larger results in cutting into it. Guess how I know! You can do very little to the Renesis exhaust ports as a result and are pretty much limited to just slightly radiusing the edges.
The Renesis engine that I ported a few years ago was a big learning experience and I did ruin one housing cutting into the water passage. Most of the port work gets done to the primary intake ports with only a bit of cleanup on the rest. That engine didn't make tons of power over stock but it did make noticably more average power than any other Renesis I've driven with a bit more peak. Don't expect 30 hp gains or anything though. You won't get them.
Skeese
65
Mar 28, 2017 03:30 PM
msilvia
28
Apr 14, 2016 12:58 PM
