Super Duper Boost Creep
Old Aug 23, 2010 | 11:34 PM
Vierte's Avatar
So yea. S5 turbo block. S4 NA Rotors. Stock S5 Turbo w/ ported waste gate. Stock Top mount. 3" single exhaust. No silly cats. Standalone with fuel to spare. 15psi boost creep!!!! in 90deg weather...
how is this thing still alive? lol. The thing is ridiculously quick for what it is. And I know the obvious answer is to man up and buy a real turbo... and a real wastegate.
My question to you is... what would you do in the meantime? park it... take it easy... beat the pi$$ out of it and enjoy it?
Old Aug 24, 2010 | 12:04 AM
SirCygnus's Avatar
whats going on?
its got a stand alone and fuel to spare, if its tuned to reach the 15 psi, go for it.
mine is stock waste gate and regularly hits 11 psi. i just call it a day and tune for it.
MaczPayne's Avatar
Mac Attack
Did you back-cut the wastegate runners when you ported it? Or did you just open up the hole at the flapper door?
Old Aug 24, 2010 | 09:01 PM
Vierte's Avatar
well its fixed. and terribly slow now. The story is i put exhaust on it, then pulled the manifolds off to seal them up better and to fix some boost leaks... put it all back together and it was much slower than before... then a couple days later the car started getting quicker and quicker.. when it started hitting 11lbs i attributed it to boost creep. when it started hitting 15lbs i got worried and started looking around. turns out the the nipple from the front of the stock compressor that goes to the wastegate blew out of the compressor housing. the car was running with no wastegate. :/
Anyway it now holds 7 lbs.. and is terribly slow. It was pretty quick at 15lbs and high compression rotors tho, too bad I didnt iphone dyno it :/
Old Aug 25, 2010 | 12:32 AM
incubuseva's Avatar
Boost knob
I think I'm having the same problem. When I put my turbo on, I forgot that vacuum hose. Then I put it back on.... But it's still hitting 13-14 PSI. Unported wastgate + stock tune.... Surprised **** hasn't blown yet.
Old Sep 11, 2010 | 01:46 AM
rotaryride's Avatar
Youngster!
I heard that you have to mess around with the CPU because of the aftermarket down pipe. I heard if it's not stock something will go wrong. Is that right?
Old Sep 11, 2010 | 09:28 AM
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
Well, putting in an aftermarket downpipe will give you boost creep. high boost means more fuel.
The stock ecu doesnt control fuel so well at boost higher then stock so you will need some way to fine tune the fuel.
Old Sep 11, 2010 | 12:09 PM
incubuseva's Avatar
Boost knob
You can't mess with the ECU in it's stock configuration. You either need to get a piggy back fuel controller like an apexi SAFC, or get a chip in it so you can tune it like the Rtek system. Or you can go with a stand alone ECU. Then you can add more fuel since you're getting more boost (more air.)
Old Sep 11, 2010 | 12:23 PM
RotaryEvolution's Avatar
Sharp Claws
only 15 psi with the wastegate unhooked? sounds like you have some boost leaks.
Old Sep 11, 2010 | 02:38 PM
Vierte's Avatar
no boost leaks. 15psi was at low rpm where i lifted, im sure it was making more but after i saw 15 i was a little too freaked out to see what it actually made.
Old Sep 11, 2010 | 02:48 PM
Sharp Claws
i see
Old Sep 11, 2010 | 03:39 PM
I remember when my wastegate line popped and I was boosting 20 psi on the stock turbo LOL
Scared me shitless...
Old Sep 11, 2010 | 03:42 PM
Sharp Claws
feel lucky that the motor survived, you should have been scared.
Cameron38
1st Gen General Discussion
Sep 19, 2015 11:45 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
