New Product: Banzai Racing Transmission Brace
Old Aug 18, 2010 | 06:37 AM
Banzai-Racing's Avatar
Rotary Specialists
IN New Product: Banzai Racing Transmission Brace
We have developed our Transmission Brace to aid in the support of the PPF and trans. Installation drastically reduces shifter movement, allowing for a much more precise and predictable shift pattern. Additionally it helps to prevent cracking of the PPF by eliminating transmission tailshaft movement.
Our Transmission Brace is fabricated from 1/4" laser cut steel, it is then press brake formed and E-Coated to prevent corrosion. It weighs only 2 lbs. Comes with complete installation instructions. Available in Black Only.
This brace is best used in conjunction with our Differential Brace and Polyurethane Motor Mounts.
Depending on the car's modifications, this brace can transmit vibration into the passenger compartment. If you have any concerns about noise or vibration, we do not recommend installation of this product.
Installation Instructions: http://www.banzai-racing.com/transmi...structions.htm
Can be purchased from our webstore $75.00 http://banzai-racing.com/store/FD_trans_brace.html
