Turn Signal
Old Jun 27, 2002 | 09:02 AM
peteb48's Avatar
Newbie
Turn Signal
All of a sudden neither of my turn signals work. The hazards work so I know it isn't a bulb. I looked at the wiring diagram and can not figure out why the hazards will work but the turn signal won't. Any ideas?
Old Jun 27, 2002 | 09:05 AM
rxse7en's Avatar
Nothing to see here.
First check your fuses. If ok, then resolder the connectors in the Hazard CPU. The CPU is located on the drivers side, behind the left kick panel in the footwell. Held on with one 10mm (?) nut and it has two connectors attached.
GL.
B
Old Jun 27, 2002 | 10:39 AM
Icemark's Avatar
CPU connections.
Resolder or replace your CPU
The1Sun
Sep 18, 2015 07:13 PM
Farkel
Sep 16, 2015 06:16 PM
The1Sun
Sep 15, 2015 04:45 PM
m_haiser
Sep 13, 2015 04:21 PM
