Air Fuel Ratio
Old Aug 15, 2010 | 08:57 PM
GreenMachine's Avatar
Air Fuel Ratio
on my 89 turbo my Wideband display shows my Air/Fuel mix to be 11-12. I was wondering how i could get it to not run so rich? Is there an adjustment? And if so where?
Thank you
Old Aug 16, 2010 | 06:46 PM
Aaron Cake's Avatar
Engine, Not Motor
When does it show these ratios? Under wide open throttle, these ratios are valid. Under cruise or idle, they are not.
Old Aug 16, 2010 | 08:34 PM
Oh it shows them all the time. It just smells like it burns really rich and the exhaust is just covered in black soot any ideas?
Thanks so much
Old Aug 16, 2010 | 09:33 PM
RotaryRocket88's Avatar
Top Down, Boost Up
If it does it when cruising, your 02 sensor is missing/not hooked up/bad. At idle, 12-13 AFR is ideal when warm, but an S5 won't have anyway to adjust this anyway.
Old Aug 4, 2012 | 09:21 PM
Tem120's Avatar
What is concidered cruising range? My car gets 15 a/f until I get past 75 mph then it starts richening up until its around 13 . ( this is light throttle ) no boost .
I'm just wondering if at 80 mph the car requires more fuel to be safe . or if the map is just being cautious ..
Old Aug 5, 2012 | 10:22 AM
Aaron Cake's Avatar
Engine, Not Motor
Cruising range is light throttle (up to about 20%) under light load. If you are harder on the throttle, richer ratios are required.
Old Aug 5, 2012 | 10:30 AM
RotaryEvolution's Avatar
Sharp Claws
is the FPR seeing vacuum out of boost? and some fuel pumps will cause rich conditions also.
Queppa
Nov 18, 2024 03:47 AM
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
alphawolff
Nov 17, 2015 05:57 PM
