Racing beat full exhaust system question
Old Aug 15, 2010 | 08:51 AM
ozziebori's Avatar
Papi Boricua
NC Racing beat full exhaust system question
I got a full RB exhaust for my 85 GSL-SE. I noticed that the system doesnt have a hole for the o2 sensor. Can i still use that exhaust system. If so, how can i bypass the sensor. Or what can i do to make it work? The exhaust system is the one with the two silencers.
Old Aug 15, 2010 | 10:19 AM
Aaron Cake's Avatar
Engine, Not Motor
Weld a bung into the collector merge for the O2 sensor.
Old Aug 15, 2010 | 09:52 PM
ozziebori's Avatar
Papi Boricua
Can i not use the sensor? Is the car goin to run rough if i dondt use it?
Old Aug 16, 2010 | 10:00 AM
geilkyle2's Avatar
your not going to want to delete that 02 if its your upstream o2. Thats a vital part of the car calculating fuel trim. Mark where you need an o2 to be, get a bung from online or check a local parts store, and just take the exhaust somewhere to a local shop and have them weld it on for a few dollars if you can't get to a welder.
Old Aug 16, 2010 | 02:09 PM
funkjaw's Avatar
Car will run fine without the O2s, but you will notice a decrease in fuel mileage.
Old Aug 16, 2010 | 02:51 PM
ozziebori's Avatar
Papi Boricua
Thanks for the info guys!!!
Old Aug 16, 2010 | 06:39 PM
Aaron Cake's Avatar
Engine, Not Motor
Yes, while the car will run fine, it will not enter closed loop. This will effect mileage somewhat.
Old Aug 16, 2010 | 07:17 PM
ozziebori's Avatar
Papi Boricua
Now that I have the full exhaust system. What carburetor can I use to replace the EFI to get the max HP from stock port in my 85 GSL-SE?
Old Aug 17, 2010 | 12:58 PM
funkjaw's Avatar
I don't know much about carb setups.
I do know you can get a stand alone and tune the crud out of the EFI it to get some decent power. Especially with bolt ons.
Old Aug 17, 2010 | 06:19 PM
rxtasy3's Avatar
well since ur going carb u CAN do away with the O2. and if u plan to keep using the stock pump, u'll need a pressure regulator.
Old Aug 18, 2010 | 03:34 AM
OriginalFake2's Avatar
It's a nice exhaust though and it sounds great!
cristoDathird
28
May 30, 2019 08:47 PM
thecody59
40
Aug 23, 2015 06:41 PM
