I fixed my idiot lights! Woot!
Old Jun 27, 2002 | 05:58 AM
Audiofight's Avatar
I was just really happy that this actually worked.
All I did was pulled the thing out and opened it up. Resoldered the points for all the pins and closed it back up.
I turned on the ignition and all the lights came on, even the clock that hasn't worked since I bought the car. Now, even the seatbelt light yells at me to buckle up.
Just wanted to share my success with someone that hopefully cares.
Old Jun 27, 2002 | 06:06 AM
CrackHeadMel's Avatar
Learned alot | Alot to go
LUCKY!
Man, your lucky, ive pulled that thing 3 times and resoderted MANY of times.. i got my hatch light and coolent buzzer light to work once... clock has never worked
sight, maby ill resoder it tonight, i cant drive it anyways =[
Old Jun 27, 2002 | 06:17 AM
silverrotor's Avatar
I resoldered It when I constantly saw my clock dim. It was like a strobe light show! Ever since I had absolutely no problems. Its as good as brand new.
Old Jun 27, 2002 | 09:00 AM
Blowtus's Avatar
short of running the car without coolant... how would I check my coolant buzzer? my clock flickers and occasionally turns off, but my door, brake and hatch lights all work fine. never seen a seatbelt light though. I'd assumed if one worked the rest would...
Charlie
Old Jun 27, 2002 | 05:47 PM
Audiofight's Avatar
My oil, gas, washer fluid lights all seemed to work flawlessly. But, my seatbelt, clock, and the rest were untested or unworking.
After resoldering, they all work (to my knowledge). I will try to run the gas kinda low this weekend to test that one and I have to open the hatch before I will know if that one is working.
Old Jun 27, 2002 | 06:05 PM
NZConvertible's Avatar
I'm a boost creep...
Pull the connector of the sensor and start the engine. The “add coolant” light should come on 9-16sec later.
rgordon1979
40
Mar 15, 2022 12:04 PM
Devon300zx
15
Sep 16, 2015 06:57 AM
rx7shirley
Sep 2, 2015 02:11 PM
