Power FC Re-tune needed with a new fuel pump?
Old Aug 10, 2010 | 11:21 PM
floatyghosthat's Avatar
Hey guys,
I just installed my Walbro 255 into my FD, and after reading a few posts, I'm starting to get scared.
Do I need to re-tune my car for a higher flowing fuel pump?
With the stock ECU, It seems like it would be fine, but I'm terrified of the Power FC. I had the car tuned last year, but unfortunately, I'm hours away from any tuner, and I have no wideband to ease my mind.
If someone could let me know, I'd be really appreciative. I had thought that the FPR should keep the flow levels the same, but now I'm starting to question that considering it's a spring based system (isn't it?),and more pressure acting on it will force it open more (won't it?).
Thanks guys!
Old Aug 11, 2010 | 07:53 PM
Vell's Avatar
It won't.
You can think about this with at least a couple of 044 ...
Old Aug 11, 2010 | 08:25 PM
great, thanks!
Old Aug 12, 2010 | 11:40 AM
arghx's Avatar
rotorhead
The only way to tell is to put a wideband on it and see what the AFR is.
Old Aug 12, 2010 | 04:09 PM
Eggie's Avatar
If your PFC was tuned with a weak pump, the tuner may have added lots of fuel to compensate for the low fuel pressure. In this case, a good pump will richen the mixture. If your old pump was keeping up with your mods, the new one shouldn't change anything.
Old Aug 12, 2010 | 04:46 PM
arghx's Avatar
rotorhead
^ That sums it up.
Old Aug 13, 2010 | 02:50 PM
cewrx7r1's Avatar
Eye In The Sky
Some much fear based on wrong assumptions and logic.
Old Aug 24, 2010 | 08:52 AM
TuRbOnOs7's Avatar
Hardcore Rx7 *****
I'm sorry but fpr is just that a fuel PRESSURE regulator... not a flowrate regulator. True, you don't have to worry about your engine blowing up, you are safer than before but I've seen cars that go from example 11.3 afr idle to 10.3 that's a whole point....just by switching the fuel pump to the walbro it FLOWS MORE fuel at the same pressure and like mentioned above.. your tuner prolly added extra fuel to keep you safe so I imagine that you were prolly running a little on the rich side to begin with now you're a whole point richer.... yeah you're prolly so rich now you're not making peak horsepower or torque anymore, on top of that you prolly have horrible gas mileage. My advice, get a wideband and get a re-tune.
alphawolff
Nov 17, 2015 05:57 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
