Far East Forum Serving Asia and surrounding Areas. Far East users, post event and club info here
soda blaster in okinawa?
Old Aug 10, 2010 | 08:52 PM
87GTR's Avatar
soda blaster in okinawa? When I lived in Texas we would use a Soda Blaster to clean parts before getting them powder coated or just cleaned up before paint and rebuild.
is there any place in Okinawa that uses Soda? I really dont want use sand or glass as small pieces can get stuck inside then work themselves out later and destroy your engine.
Old Aug 11, 2010 | 08:28 AM
87GTR's Avatar
I have search around and im going to end up buying my own soda blaster. so if your in Japan and want something blasted let me know.
Old Aug 19, 2010 | 06:24 PM
Circuit Theory's Avatar
japan connection
I have never heard of a soda blaster. It sounds like a great Idea but I am a bit confused about what the actual material used to blast with is??? Baking soda? Soda-cola-dr.pepper?
If it is baking soda then do you just substitute it for the sand or do you need a different type of set up with higher pressure or more filtration?
Also assuming you are using baking soda, do you only use this process for very fine finish prep work? I am sure you can whack dirt or impurities off of parts with almost any material if you are blasting at the right pressure however baking soda strikes me as not being very abrasive.
Ok I guess I better check into this some more. sounds like a really interesting/good idea 87GTR!
Old Aug 20, 2010 | 03:06 AM
N3philum's Avatar
Shikkaku Dori
I dont know of any Soda blasting places. I can ask around though. I know of a sandblasting place or 2 but... Thats it.
Old Aug 23, 2010 | 06:45 PM
87GTR's Avatar
yeah it uses industrial grade sodium bicarbonate (soda) not the same kind you get off the shelf at the store.
what is cool about soda is that it wont pit or scratch the metal like sand does. Also it does not get stuck in little ports and later work it way out and into your motor. I have seen when using glass beads they get trapped in the intake manifold and when they work them self back out they do not compress in the rotor housing and kill the engine.
and when your done just rinse them off with water to clean out any extra soda left on the parts.
here is a few pics I will try and find some better ones later
These are from Texas when we used Soda Blaster there.
http://www.sodablasting.com/ They soda blasted the Mustang in the moive "gone in 60 seconds" instead of acid dipping.
breakdown a Cosmo 13BRE
look at how dirty the front cover is.
this is after soda getting read to coat the parts.
back from the coaters
Old Sep 6, 2010 | 06:13 AM
N3philum's Avatar
Shikkaku Dori
Sexy!
nycgps
30
Sep 29, 2015 12:02 AM
