Fuel Pressure Help
Old Jun 26, 2002 | 09:50 PM
Wargasm's Avatar
Weird Cat Man
Arrow Fuel Pressure Help
I am upgrading my fuel system and I can't seem to get enough fuel
pressure. I don't know what I was getting before I ripped my car apart
because I never measured it.
My mods:
"RX-7 Store" upgraded fuel pump. I think this is the Nippon Denso one
for Cosmo/Supra(??)
Mallory 4309 Adjustable 1:1 FPR (3-65 PSI Base)
1600 cc/min secondaries + k2rd rail (no stock FPR)
TWO different fuel pressure gauges for a sanity check while installing
Anyhow, even with the Mallory cranked all the way to max, the best I can
do with the car OFF is around 35 PSI.
When I crimp off the return line to test FULL pressure, it goes up to
maybe 40-45 PSI.
I hooked up a heavy duty battery charger (on engine start mode) to give
the pump more juice and this helped a little. My numbers with the
return line blocked went up to about 60 PSI or so. This is still
pathetic.
The ONLY thing I can think of that is broken is when I put in the new
pump, the little plastic O ring thing that snaps on to the top of the
fuel pump broke. I just put it back in with a crack in it. Could this
be bleeding off pressure?
Is that fuel pump just a POS? How can I test my fuel pump wiring for
proper amperage delivery?
If the fuel pump is a piece of junk, where can I get the Bosch one?
Thanks,
Brian
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
