Help!
Old Aug 8, 2010 | 03:35 PM
cheiwe306's Avatar
Unhappy Help!
Hello and good day i just bought a 92 rx-7 13 b rhd a couple days ago at first it had a little starting issue but after old gas was gone it was fine i just woke up today and went for a "short" drive as soon as i left my block the car made a clicking sound and all the sudden shut off on me tried starting it but wouldnt go, finally got it started ran very rough and kept wanting to stall out. Pretty much new at the roatary engine so any help would be awesome thanks have a great day
Old Aug 9, 2010 | 05:46 PM
JesTerI3's Avatar
Wilhelm!
Need a little more information to troubleshoot further, what was the car doing and what sounds would it make when you tried to start it/ how did it act? how did it drive before the car stalled?
I had a problem with my 89 gxl starting, i would have to try a few times to start it (it wouldnt crank) and found out, the wiring from the battery and alternator were corroded and it did in fact die and ran kinda crappy. As for the clicking, do you have any clue where it may have been coming from?
Im an electrician and have worked on cars most my life, iam quite new to the rotary engine as well so i have limited knowledge (but im learning) about the rotary.
Old Aug 9, 2010 | 06:44 PM
T2mike222's Avatar
Is the car modified?
Old Aug 10, 2010 | 02:00 PM
cheiwe306's Avatar
just put a boost gauge in the day before other than that the car is stock, I did a compression test on it and the rear rotar has none so im guessing my apex seals are shot anyone know of a place that i can get a rebuild kit for it only have had the car for three days
Brandon
Old Aug 10, 2010 | 03:09 PM
Go48's Avatar
Check out AtkinsRotary.com or RacingBeat.com for a rebuild kit. You might want to purchase a video that walks you through the rebuild process. Atkins has one as does Mazdatrix.com.
Old Aug 10, 2010 | 11:30 PM
gracer7-rx7's Avatar
needs more track time
You need to put more thought into what you use for a title if you actually want help.
If your engine is blown, go to the Canadian section and read the sticky with Canadian shops
https://www.rx7club.com/canadian-forum-42/
