S5 thread pitch stock water temp sensor
Old Aug 8, 2010 | 01:19 PM
finishline's Avatar
Not Even Foo
what is it? after reading some threads, i'm under the assumption that it is 1/8" NPT. but RETed says it's 1/8" BSP. mind you, my block is an S5 and not S4.
here's the thread i used as reference:
https://www.rx7club.com/showthread.p...tch+water+temp
thanks.
Old Aug 8, 2010 | 01:27 PM
arghx's Avatar
rotorhead
so are you talking about the water pump housing sensor (2 wire) or the rear iron sensor (1 wire)?
Old Aug 8, 2010 | 01:28 PM
finishline's Avatar
Not Even Foo
rear iron for the gauge. should've been specific. sorry.
Old Aug 8, 2010 | 01:35 PM
finishline's Avatar
Not Even Foo
"temp gauge sender"
this one.
Old Aug 9, 2010 | 12:08 AM
finishline's Avatar
Not Even Foo
scratch it. went to home depot myself and found out the size. 1/8" NPT it is.
Old Aug 9, 2010 | 12:22 AM
Rx-7Doctor's Avatar
http://www.napaonline.com/Search/Det...+50042+2042026
Old Aug 9, 2010 | 11:15 AM
RockLobster's Avatar
Let's get silly...
It is NOT 1/8" NPT
It is 1/8" BSP.
If you are REPLACING the oil pressure gauge or water temp gauge you need this.
http://www.pegasusautoracing.com/pro...asp?RecID=3142
If you are ADDING an aftermarket gauge and want the stock one to continue working you need something like this.
http://www.pegasusautoracing.com/pro...s.asp?RecID=56
Although i have not used one of these before and have no idea if it will fit, considering how close these two ports are to one another.
Old Aug 10, 2010 | 11:17 AM
finishline's Avatar
Not Even Foo
sorry guys, got a little impatient.
i'll make sure i'll do it right then. time to get that adapter...
any local store that would have such a thing?
i kinda scanned home depot pretty fast and didn't catch anything.
Old Aug 10, 2010 | 11:21 AM
Let's get silly...
Probably not your typical AutoParts Store, but call around.
There are plenty of performance parts outfits in Calli...
I just order more locally because the stuff gets here in a day or two...
Old Aug 10, 2010 | 12:51 PM
Rx-7Doctor's Avatar
Sorry I thought by that link he would have realized that it was BSP.
http://en.wikipedia.org/wiki/British...rd_pipe_thread
http://www.napaonline.com/Search/Det...+50042+2042026 original link.
Old Aug 12, 2010 | 12:24 AM
Rx-7Doctor's Avatar
Besides Nap Auto parts this is the only other source I have found for the 1/8 BSP to 1/8 NPT adapter. I am sure someone else supplies it but I did not find anything on Stewart Warner or the VDO website-
http://www.autometer.com/cat_accesso...il.aspx?vid=59
#2269 Autometer.
http://www.jegs.com/i/Auto-Meter/105/2269/10002/-1
Which is cheap compared to what Napa wants for theirs which is only available in a 2 piece set. Cost $30.00
For other reference adapters.
http://www.jegs.com/p/Auto-Meter/Aut...49158/10002/-1
Old Oct 27, 2010 | 04:20 PM
finishline's Avatar
Not Even Foo
so i bought the adapter good while back but barely had the change to put it on recently.
sure enough, the sensor was bigger in diameter than the adapter's hole.
used these guys to make the hole bigger
and had to make do with what i had.
even though i made the hole big enough, the threads DID NOT match.
it's much more coarse (sp) than the fine threading of the sensor.
i don't know if the threading was vice versa (the outside being the threading on the inside and inside being out) but all i know that it didn't fit.
not really asking much but just wanted to share what happened. i just ended up putting the water temp sensor back in without the adapter.
Old Oct 27, 2010 | 04:29 PM
clokker's Avatar
Cake or Death?
The 1/8 BSPT and 1/8 NPT will interchange.
The difference is the first has 28 threads per inch the second has 27 threads per inch and from a practical perspective, the taper will lock before the thread discrepancy matters.
I've done it several times without leaks or thread damage.
Old Sep 9, 2011 | 03:51 PM
Youngx7's Avatar
sorry to bring this thread back to life but iv been looking around and havnt found anything yet. but does anyone know what color wire goes to the temp gauge sender? mine is a 93 3rd gen. thanks guys
sherff
Feb 24, 2019 12:09 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
GrossPolluter
Aug 16, 2015 09:50 AM
