S4 oem nonturbo exhaust on S5-t?
Old Aug 8, 2010 | 08:05 AM
lovespeed's Avatar
i have an S4 oem exhaust from a nonturbo that i'd like to put on my s5-t because of the rice cannon.
would there be any problems with the exhaust flow?
Old Aug 8, 2010 | 03:34 PM
RotaryRocket88's Avatar
Top Down, Boost Up
If you're talking about a cat-back system, the non-turbo version is almost exactly the same as the OEM turbo cat-back. I think the mufflers are slightly more restrictive/noise canceling, but the y-pipe should be the same diameter.
Old Aug 8, 2010 | 06:22 PM
lovespeed's Avatar
Thank you so much RotaryRocket88
Cordt's Avatar
the cats are probably a lot more restrictive than the mufflers, no? especially since they are probably clogged to hell
FD7KiD
15
Feb 26, 2021 10:12 PM
sYnth.
Aug 19, 2015 06:27 PM
FD7KiD
Aug 17, 2015 11:50 PM
