do i have to switch to 5 lug???
Old Aug 6, 2010 | 08:35 PM
timelessdigity's Avatar
YAY! Rebuild Time
IL do i have to switch to 5 lug???
hi, my 87 rx-7's motor just crapped out and im thinking of doing the turbo 2 swap. i know i have to have the driveshaft and diff, but do i have to swap to 5 lug before driving it? thanks in advance.
Old Aug 7, 2010 | 01:38 AM
RotaryRocket88's Avatar
Top Down, Boost Up
Read the 2nd gen FAQ. There is plenty of information on turbo swaps. The hubs have nothing to do with it.
Old Aug 7, 2010 | 08:13 AM
Ken7102's Avatar
You should be able to keep your current hubs
Old Aug 7, 2010 | 09:03 PM
misterstyx69's Avatar
Retired Moderator, RIP
You can keep the hubs.
the setup will be the TII half shafts with 4 lug wheels,and Crappy brakes(fronts will be single piston Right?) but hey,at least you will have more power to Hit the Car HARDER!..J/k.
I am just trying to say that if you are putting a TII engine then you really should Upgrade the brakes too.when you can.it's only a reasonable upgrade.
