what model do I have
Old Aug 5, 2010 | 05:11 PM
shadtree's Avatar
I have an 85 RX-7, 12a with no markings on the body to designate whether it's an S, a GS, or a GSL or a GSL-SE. I suspect the lack of body markings means that it's an S. The vin number doesn't seem to give any clues: JM1FB3318FO892517.
Thanks, Dennis
Old Aug 6, 2010 | 06:34 PM
Ken7102's Avatar
do you have the car manual? if not you could try comparing the different features (internal and external)
Old Aug 6, 2010 | 07:19 PM
FelixIsGod29X's Avatar
Manual Rack
If you have rear disc brakes and a front oil cooler then its a GSL i think. If not then its a GS,S or base.
Old Aug 7, 2010 | 12:00 AM
rxtasy3's Avatar
there's already a thread somewhere that tells what model had what options. but if urs is drum brake rear, that rules out gsl. and it being a 12a, that rules out gsl-se.
Old Aug 7, 2010 | 10:16 AM
Ken7102's Avatar
You probably have a GS
Old Aug 7, 2010 | 11:28 AM
shadtree's Avatar
model
Thanks for your posts. I do have the owners manual, but there doesn't seem to be anything in it to give me a clue. You would think that the vin number would contain a code for the model number, but it doesn't. The rear brakes are drums not discs, so I guess that rules out the GSL. I guess I'll have to be satisfied with knowing that it's either an S or a GS. Dennis
Old Aug 8, 2010 | 10:05 PM
Ken7102's Avatar
sorry i couldnt help you out anymore, but hey at least you have the Rx7 =D, you should post a pic of it
Old Aug 8, 2010 | 10:52 PM
Cordt's Avatar
does it have that horrible oil cooler mounted under the oil filter? thats the only thing i would be worried about.
Old Aug 9, 2010 | 06:13 AM
shadtree's Avatar
yes it has the oil cooler. why is that bad?
Old Aug 9, 2010 | 08:52 AM
rxtasy3's Avatar
no it's not bad. others just prefer the one that goes under the rad.
Old Aug 9, 2010 | 05:32 PM
Cordt's Avatar
yeah the one that actually works lol
turbojeff
Oct 5, 2015 10:50 AM
Jingkun
Sep 28, 2015 01:53 PM
