Megasquirt S5 tps wiring
Old Aug 2, 2010 | 09:55 PM
wankelbug's Avatar
S5 tps wiring
ok i know i post alot of simple questions but hey we all had to learn right??????
so im using the S5 TPS in my build do i use both the TPS or just one? and how do i go about wiring them? the top one is a long range i understand so if i used just one logic tells me to use just that one.
Old Aug 3, 2010 | 08:51 AM
Aaron Cake's Avatar
Engine, Not Motor
The full range TPS is the best one to use. I don't know the wiring off hand, but it is easy to find. Using a meter, find two wires that always show the same resistance regardless of TPS position. Then disconnect one of the probes from those two wires and find the third wire that changes resistance as the TPS moves. You have now found your TPS wires. If the resistance falls when you move the TPS towards WOT, then the + probe wire gets 5V ref. If it is opposite, then the - probe wire gets 5V ref.
toplessFC3Sman
Mar 20, 2018 01:54 PM
ZacMan
Sep 19, 2015 09:20 PM
