Power FC Datalogit logging issues with Windows 7
Old Aug 2, 2010 | 02:12 PM
alemmons's Avatar
89 GXL Turbo
Veteran: Marine Corp
I am running Windows 7 Professional 64 bit. Datalogit is running and I can log for a little bit, but after about 5 minutes the whole system crashes. Never has stability issues when I am not logging. Is this common? Should I put a partition for XP and use that for logging?
Old Aug 2, 2010 | 04:51 PM
ttmott's Avatar
That's interesting - I was going to upgrade my OS also.... Did you emulate the USB port as a RS232 port like it needed to be done in XP?
Old Aug 2, 2010 | 06:26 PM
arghx's Avatar
rotorhead
I'm using Windows 7 32 bit and haven't had a problem.
Old Aug 2, 2010 | 09:27 PM
cloudzero's Avatar
I'm using win7 64bit also and am not having any problems, what kind of computer are you running? I would make sure you have enough system resources for it, system ram, hdd space etc. I can log for hours with no issues, Also what brand cable are you using? I had an older one from radioshack that i used to log on my xp laptop and and win7 32bit laptop, but when i bought my new one in 64bit it would detect the cable but would freeze up and give me errors with the datalogit, Went to radioshack and bout a new one from gigaware part #26-949 and it works like a dream.
Old Aug 2, 2010 | 10:08 PM
alemmons's Avatar
89 GXL Turbo
I am running a custom laptop. I have 2GB ram and over 8GB free on the hard drive. Shouldn't be a problem there. The cable is new, I can't remember the brand, but it starts logging and logs fine for awhile, just locks up after a bit.
Old Aug 3, 2010 | 11:39 PM
cloudzero's Avatar
i think the minimum for win7 64bit is 2gb of ram, so maybe when logging it just runs out of system resources and crashes. not to sure, you could always try a xp partition and just run the basics and see if it works or not.
Old Aug 5, 2010 | 12:39 AM
alemmons's Avatar
89 GXL Turbo
Turns out it was the usb adapter. I tried another one and it seems fine.
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
yetter227
20
Sep 5, 2015 11:57 PM
rotor_veux
Sep 3, 2015 07:10 PM
