Rotary Drag Racing The place to post your racing stories and info
NZ 20B PP Triple Turbo RX2
Old Jul 27, 2010 | 07:03 PM
Jimbo II's Avatar
Rotating
Hey guys
I don't post in here very often so I am unsure If you have seen this already or not. Its the CBR (Curren Brothers Racing) Rx2 from New Zealand.
Is said to make between 900-1400hp atw's at 9600rpm. If they can get all the power down on our shitty drag strip then it should go very deep in the 7's this year. They may end up taking it to Australia for their better tracks.
Anyway enjoy the pics just thought I'd share this beast with ya'll
Old Jul 27, 2010 | 07:28 PM
ALNY93R1's Avatar
Sick!!!!
Old Jul 27, 2010 | 09:16 PM
RoTaRyBoYz's Avatar
InsaneRotaries.com
Brent did an awesome job on that car. He even stuck with the el cheapo Master Power turbos
Old Jul 27, 2010 | 10:15 PM
Viking War Hammer's Avatar
*** Bless The USA
Wow!
Old Jul 27, 2010 | 10:30 PM
ultimatejay's Avatar
I thought this car had a 13b? Did they recently switch over to the 20b?
Old Jul 28, 2010 | 02:18 AM
Jimbo II's Avatar
Rotating
Yeah it was running a 13B it did a 7.6 @170 or something like that. This new package should be a bit more potential!! Master power turbos FTW haha!
Old Jul 28, 2010 | 08:25 AM
rotaryB-2000's Avatar
Psalms 37**25
whooo...whoooo.....900-1400HP...thats two different worlds..be carefull with these types of claims..
Old Jul 28, 2010 | 03:27 PM
CBR's Avatar
CBR
We use to run the 13b with the same turbos which went 7.70 at 174mph and consistant 1.12 60's, we never got the chance to run any real psi through it but Im confident it would of been good for 7.50's maybe even .40's.It only ever saw 32 psi.Car now has a new cs3 lenco.we will probably never be able to use all the power that the 3 rotor will make but I will sure as hell give it a goThis little baby is our hotrod to not just a race car and Ive always wanted to build this package for a long time.900-1400hp means it can run anywhere from 900 to 1400,depending on track,gears and how big my ***** arewe will probably only ever use 1100max as a low 7 is all we are after.Also I want to see how far we can go with out an adjustable clutch.Thanks for the comments.nothing like a challenge ha
cheers
brent
Jimbo II's Avatar
Rotating
Just from their website:
Now that we have had a break from racing as it is the off season we have decided to fit the larger 20b 3 rotor engine. It will be fitted with our billet crank, light rotors, peripheral ports, oil system, hand fabricated intake and exhaust systems, 3 x Master Power turbochargers, 3 x 60mm wastegates, 18 x 1700cc injectors and Microtech engine management. It will produce anywhere between 900 and 1400whp depending on boost level and tune up. All work is designed, built and fitted by CBR, our goal is to run consistant low 7's and still have the reliability that we are known for, we also want to see how far we can go without the use of an adjustable clutch.
http://www.curranbrothersracing.co.n...Garage_Updates
EDIT: Just beaten!
Old Jul 28, 2010 | 03:41 PM
hondahater's Avatar
spending too much money..
Why use masterpower on a setup like that? I'm surprised the masterpower turbos could handle 32psi.
Old Jul 28, 2010 | 04:10 PM
BurntOrangeT2's Avatar
No phonebook but OG calls
I just filled the cup.
Old Jul 28, 2010 | 04:17 PM
Gryffinwings's Avatar
This is NUTS!!!!!! Triple Turbo, Triple Rotor, and apparently, triple stages fuel injectors, geez!!!
Old Jul 28, 2010 | 09:45 PM
prrex4ever's Avatar
Now What?
Sweet!
Old Jul 28, 2010 | 10:47 PM
CBR's Avatar
CBR
Why not use masterpower? I have seen small frame ball bearing garretts **** them selves,large frame to.Aussie billet turbo fell apart along with a gt55 on the same 13b,now back to the masterpower.also with no bov's.I run them in 400hp 13b and 500hp 20b track cars with no issues,never seen one fail still with no bov's.Im also not shy to sit on the 10,000rpm 2 step for a long time either,As long as the wheels are in good shape and clearances are good then there should be no problemnot sure if I need to say anymore but I have proven them to be reliablealong with many others.Hopefully one day I can get 32psi through the 3 of them on the 20b,that will be fun
brent
Old Jul 29, 2010 | 05:05 AM
beefcake's Avatar
pushing s##t up hill
good **** brent , no point bandwagoning **** becuase everyone else does it, i like your jibe sonny
Kyo
Apr 13, 2019 09:24 AM
Jan 11, 2016 04:08 PM
sleepydogz
Aug 25, 2015 07:55 PM
20B Forum
Aug 18, 2015 02:46 PM
