cluster and tail lights don't work
Old Jul 27, 2010 | 01:27 AM
anthonyl0624's Avatar
CA cluster and tail lights don't work
I been trying to get this problem fix, but can't seem to figure this one out. clusters lights and tail lights, and my 99 spec front bumper lights don't come on.. checked all my fuses including the meter one everyone is good... Anybody have any suggestion on what I should look for...
Old Jul 31, 2010 | 02:36 AM
CA cluster and tail lights...
I fixed the problem....
Old Aug 2, 2010 | 05:10 AM
are-ex's Avatar
Brewster
what was wrong im having a similar problem
Old Aug 3, 2010 | 03:04 AM
There's a thick black harness to the left of the fuse box under the steering colum. The wires on them were messed up and it didn't send the right voltage to the TNS relay. I checked everything else and could figure it out until I pulled on that harness and it started to turn my cluster lights on and all my other lights. You will see that black harness and there should be a big white connector check that also....
Old Aug 4, 2010 | 12:24 AM
are-ex's Avatar
Brewster
oh ok i'll play around with that
Old Aug 4, 2010 | 12:38 PM
97SupraTwinTurbo's Avatar
Trackstar motorsport
Anytime you have a problem with gauges or tail lights, the first step would be to take a look at the fuses, wiring, and the relays associated with the affected part. Once that's clear you can get into the actual part itself and figure out if it's damaged and if there's electricity going to and from it.
Old Aug 5, 2010 | 12:36 AM
Jared FC's Avatar
If anyone needs help with this issue I made the same thread about a week ago. The main problem is in there as well as posts and links on how to fix it. I just replaced the switch and wiring that gos to it and wired tail lights with a lead wire because the used harness I had was still crappy.
