Sponsored by: CARiD
Timing is off... BAD
Old Jun 25, 2002 | 11:17 PM
hey... i had an earlier post, but the title was unattractive i suppose...
the timing on my car is very off, no matter how much i turn the CAS (to its limit one way or the other), the timing will not align. it is too high (the lines are towards the passenger side of the car about half an inch. ive redone the timing, pulling the CAS out, aligning it with the small mark (the small one nearest to the top of the CAS), then dropping it in. did i do this correctly? also, my battery is relocated to behind the passenger seat, would this affect the timing? what else could it be? thanks, Jordan
Old Jun 26, 2002 | 06:27 PM
T2 Tsunami's Avatar
Stud Service
I have the same problem. I was wondering if the actual pulley could be off by one notch, because the car idles smooth just a little on the low side.
Old Jun 26, 2002 | 09:14 PM
tsunami
i fixed it now... what i did is took of the top of the CAS and dropped it back in... with the top off, you can see if the sensor moves while you drop it in... throwing it off by a notch. try that... also, you can retard or advance your timing just a bit to line it up as i had to... simply move the main drive pulley marks in front of or behind the pointer, and then drop the pulley back in... to time it normally, for the leading coil, line up the yellow mark and drop the CAS back in. hope it works dor you
Old Jun 27, 2002 | 12:27 PM
j9fd3s's Avatar
Community Builder
the fc is tricky that way those pins at the bottom dont alagin the cas. you have to take the cover off
mike
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
