my rx7 TII on the dyno tune at 13 psi 317hp
Old Jul 17, 2010 | 10:08 PM
Dzire's Avatar
rx7 TurboII 317 hp at 13 psi stock port motor built by Rick Engman at mazmart BNR stage 2 turbo 720 injector haltech platinum sport1000 front mount intercooler dyno tuned by me
http://www.youtube.com/watch?v=AcLgwXAISqc
Old Jul 18, 2010 | 12:03 PM
BDC's Avatar
BDC
BDC Motorsports
Nice job, Hobbie. Bryan told me about it.
B
Old Jul 18, 2010 | 12:34 PM
Dzire's Avatar
At 13 psi i had 16 degrees on a timing felt like i could give it more but the temperature outside with 91 degrees 80 percent humidity so i stop right there
Old Jul 18, 2010 | 03:04 PM
Nick_d_TII's Avatar
Nice pull and numbers... solid torque and hp just keeps climbing, I bet that's a fun ride! Any pics of the engine bay?
Old Jul 19, 2010 | 12:07 AM
Dzire's Avatar
thanks it is a blast to drive just can't keep the wheels to stick to the ground this is the first time I used a haltech to tune and I am loving it don't know how I lived without it before it only took 10 pulls to tune the car
here's a picture of under the hood picture was talking when I had the rtek2.1
Old Jul 19, 2010 | 10:31 AM
junito1's Avatar
F**K THE SYSTEM!!
nice numbers.
Old Jul 19, 2010 | 10:16 PM
Dzire's Avatar
thanks a lot of work has went into this car are still a lot more to do
Old Aug 2, 2010 | 10:31 AM
10thAEWHiteHeat's Avatar
Any changes or new numbers to your setup?? I am trying to make 350whp and 300tq with the same turbo at 15 psi so i am liking what i see here so far
Old Aug 2, 2010 | 11:04 AM
Dzire's Avatar
I'm sure that I can get 350 out of it I am going to go back when it starts cooling down i was very conservative on the timing and when i go back i m going to log the exhaust temperature hopefully i could give it more timing
Old Aug 2, 2010 | 06:01 PM
arghx's Avatar
rotorhead
Eventually you should be able to set up your IAT correction table so that it will run those extra couple degrees when it's cooler outside but you will stay safe in this kind of hot weather.
Old Aug 2, 2010 | 09:17 PM
Dzire's Avatar
that's a good idea I do have it set up in the higher temperature to take away timing but I never thought of giving some timing in the lower temperatures
by the way I have read a lot of your posts and learned a lot from reading your stuff
I have also used one of your timing tables on the rtek system and the car ran great with it so I think you
Old Aug 2, 2010 | 11:06 PM
SirCygnus's Avatar
whats going on?
you got it built by the best rotary engine builder in the world.
Old Aug 2, 2010 | 11:18 PM
Dzire's Avatar
yes he is the best in the world I am going to try to get him to build me a another engine a 13b rew for big horse power trying to get in the 600 club
Old Apr 12, 2011 | 06:09 PM
junito1's Avatar
F**K THE SYSTEM!!
HOw is your boost so stable with the BNR. I took a quick look at the PSI graph and damn.. SOLID!!
Old Apr 13, 2011 | 07:09 PM
dennis blackstone's Avatar
is it hard to use the platnum sport
are you using the stock map
what are you using for primarys and secondarys
did you install the sport
Old Apr 14, 2011 | 02:09 PM
arghx's Avatar
rotorhead
I believe that is a DynoCom dyno. Their plots are heavily smoothed. The size/resolution of the image also make it look smoother. If you ever play around with certain dyno software you would know what I mean. Here is a dyno sheet from a 2006 WRX using the same type of dyno:
Old Apr 14, 2011 | 07:03 PM
junito1's Avatar
F**K THE SYSTEM!!
Is that a setting in the software or does it always smooth out the graph readings? Wouldnt that be a bad thing by hiding/smoothing out the readings therefor hiding certain imperfections?
Old Apr 15, 2011 | 09:15 AM
arghx's Avatar
rotorhead
Too little smoothing and it becomes nearly unreadable. Less smoothing can also bump up the peak numbers a bit. Too much smoothing and you hide imperfections, but it is more aesthetically appealing. Most people don't know or think about smoothing. People assume the tuner (or the turbo or whatever) is really good when they see a smooth line. It's just another complication with dynos, and another reason to be skeptical of what you see on the internet.
Allow me to give some more concrete examples. In both the Dynojet and Dynocom software (which are available free online), the smoothing can be set from 0 to 5. Some software, like the Virtual Dyno "road dyno" software, has a higher range of settings, so smoothing can go up to like 15. On a Dynojet, the default smoothing setting is 0 and there is a slider bar on the main screen. On the Dynocom, the default smoothing setting is 4, and the option is changed in a pull-down menu. The Dynocom smoothing algorithm is more aggressive than Dynojet's.
This isn't a perfect comparison (some runs can be noisier than others), but here is a Dynocom plot with the default "4" smoothing:
Here is a Dynojet plot with a setting of "4" for smoothing:
So 99% of people seeing these curves are going to assume that the Dynocom plot, which is at the default smoothing setting, is cleaner-looking. That makes the tuner look good as well as the engine management, the parts installed, and the engine itself. But the reality is more complicated. Now like I said, every dyno and run could be different so some are going to be noisier than others. I don't want to post any more big pics but if you look in my attachments you can also see a comparison of Dynocom vs Dynojet on a setting of "1" for smoothing.
Attached Thumbnails my rx7 TII on the dyno tune at 13 psi 317hp-dynocom_smoothing_1.jpg   my rx7 TII on the dyno tune at 13 psi 317hp-dynocom_smoothing_2.jpg   my rx7 TII on the dyno tune at 13 psi 317hp-dynojet_smoothing_2.jpg   my rx7 TII on the dyno tune at 13 psi 317hp-dynojet_smoothing_1.jpg
Old Apr 16, 2011 | 09:22 AM
junito1's Avatar
F**K THE SYSTEM!!
HOly crap.. On the first fraph of the attached thumbs. AT 3.5 rpms there is knock right?
then the smoothing out hides that knock on the second graph?
Old Apr 17, 2011 | 11:31 PM
AmviciousRav's Avatar
GTR
what kind of front mount are you using btw? and bov as well
power numbers look awesome for a stock port (it's a s4 block right?)
get the damn 1/4 mile times already
Old Apr 19, 2011 | 07:00 PM
Old Apr 23, 2011 | 12:33 AM
Dzire's Avatar
wow I toally forgot about this thread 720 injectors all the way around rick has built me a new motor should be on the dyno after break in it is not hard to use the platinum 1000 and I built my own map
Old Apr 24, 2011 | 08:30 AM
arghx's Avatar
rotorhead
Umm, maybe? You can't necessarily be sure just by looking at the dyno sheet alone, out of the full context of being there. Your typical chassis dyno produces noise, torque spikes, and lost tach signals all the time. It's up to the tuner to figure out if it's knock, a torque spike due to the dyno messing up, a torque dip due to insufficient timing or incorrect mixture, or whatever. Sometimes the way the car is strapped down has a big effect, or how well the dyno has been maintained
Maybe. Too much smoothing and you hide potential flaws in both what the engine is doing and noise from the dyno itself. Too little smoothing and the dyno plot is practically unreadable. Heavy smoothing definitely makes everything look pretty at the expense of a little bit lower numbers. As cynical as it sounds, most customers want a pretty dyno sheet and a high number more than anything else.
Old Mar 24, 2012 | 12:02 AM
BOVFEVER's Avatar
nice and questions
hey man ive got a T2 pretty much just like yours ive got the sport 1000 also havent installed it yet, should being doing the lil bit of wiring required tomarrow....i got the terminated harness so its mostly just plug and play....but let me know what you think of the sport 1000 and where did you get the base map from ive tried to load it from haltech site, i downloaded it and tried to open it with the haltech software open it and its just trying to tell me how to use the haltech rather than opening the base map to a edit screen...?!?! lol do i have to have it pluged to the ecu with power for it to show me whats up or what?
Old Mar 25, 2012 | 02:00 PM
Etan's Avatar
Those are good numbers.
