Rear end swap
Old Jul 17, 2010 | 07:36 PM
Silver Tuxedo's Avatar
Spy Hunter
WA Rear end swap
I have a 86 and I have a 88 parts car
the 86 is a four lug and the 88 is a lsd five lug
can I put the five lug under the 86, and bolt it on with out modification
or what is the procedure to swap
or can you not swap at all
Old Jul 18, 2010 | 02:57 AM
Josh18_2k's Avatar
just swap everything over that looks different. it all bolts up
Old Jul 24, 2010 | 04:17 PM
Spy Hunter
WA Center housing change
Can you use a 4 lug center housing (referring to the rear end) and take the guts, if you will, out of a lsd five lug and put the guts into the four lug center housing and put the five lug spindles in also?
or can they not interchange
Or is the five lug lsd a heavier duty center houseing?
just curious really
Old Jul 24, 2010 | 10:24 PM
misterstyx69's Avatar
Retired Moderator, RIP
you can take your Open end Diff right out and change it for the N/A LSD.
it will hook up to a 4 or five lug rear spindle assembly
BUT you can't use a TII LSD with N/A half shafts.,they wil not fit on the Differential flanges.
Look into TII Diff swap..or Open diff to LSD swap with the "search Function".that should give you more info.Good Luck.
Old Jul 25, 2010 | 09:45 PM
Rxmfn7's Avatar
Do a barrel roll!
You "could", but not sure why you would? Swapping rear ends on an FC is cake. If I were you Id just swap entire rear subframe in one piece. You can literally do this in under 2 hours and thats taking your time.
just curious really
Old Jul 25, 2010 | 10:08 PM
Spy Hunter
WA like I said
Well just curious really but I was planning on dropping the whole rear end out anyways.
I believe you can do it under two hours
We drop the whole front support with the engine in tranny so I think we can handle the rear end
Th0m4s
Feb 26, 2019 02:04 AM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
