Canadian Forum Canadian users, post event and club info here.
quick Questions about motor building
Old Jul 15, 2010 | 02:41 PM
Bwek's Avatar
High Comp Booster
hey guys just a couple quick questions
For the Omp Holes in the housings and intake manifold I went to canadian tire and bought M10x1.50 Bolts but they are slight long and dont bottom out Can i use High temp rtv and tighten them down? would that be effective Or should i just get some nuts on the Bolts and use the copper gasket
And for setting the end play on the e-shaft once the motor is together do I have to put a flywheel on and torque it down?
Old Jul 15, 2010 | 03:33 PM
Nismo Convert86's Avatar
400WHP or bust
Just get a m10x1.5 nut spin it on, grind off as much as you need to, and spin the nut off, no burr to worry about.You can use a copper washer, won't hurt anything. A Die of the same pitch does the same thing.
You don't need to have the flywheel on, but most people do, just because it's done, you can take your reading off the main pulley as well.
Old Jul 15, 2010 | 05:20 PM
Buggy's Avatar
I've Been Wankeled!
I'd put the flywheel on and have it all torqued to spec to measure it. It really shouldn't make a difference, but you don't have to touch it to adjust the endplay anyway. If there is a problem you can still leave it in place.
Old Jul 15, 2010 | 05:21 PM
Bwek's Avatar
High Comp Booster
i figure i can get the reading off the pully i torqued it down and there was so much play i couldn't believe it... Im going to try again I did it without the flywheel on So i wasnt sure if that was the cause
I dont wanna grind im lazy okay ca'mon Id rather push a car with my car than get out and push it on foot
Old Jul 15, 2010 | 05:34 PM
misterstyx69's Avatar
Retired Moderator, RIP
I used longer bolts and cut them with a dremel,Then I took the copper crush washers that were On the Oil injectors and used them on the Bolts.
end play?sorry man,,don't know what you are Torquin about!
Old Jul 15, 2010 | 05:48 PM
Bwek's Avatar
High Comp Booster
Well the actual Flywheel that i'll be using is in the car still I only have this Fd Flywheel sitting here
Old Jul 15, 2010 | 05:53 PM
400WHP or bust
Here is a video:
http://www.rebuildingrotaryengines.c...tting_end_play
Azevedo
26
Mar 1, 2019 09:19 PM
hotshot2014
Jul 18, 2017 02:30 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
